nitrous bottle under the bed?
Old Sep 9, 2009 | 10:22 AM
tommy1005's Avatar
Purge into the frame rails and bottle under the bed. It's what I plan on doing.
Old Sep 9, 2009 | 08:06 PM
schino's Avatar
i tested it out before i posted this up yesterday. i can lay next to the truck and get the bottle way up in there. only problem i see is if i mount it in front of the leaf spring it will come to the edge of the front of the bed and you may see it lookin down between the cab and the bed. it could be mounted more next to the leaf spring or back and above it some but the brackets would have to be more extensive. as it is id need to make my NOS brand brackets into a hinge type or just machine/fab some new ones. id like for everything to be hidden. id like to have that little 4.8 puttin down 450 at the wheels runnin 12's with nothin under the hood!
thanks guys for the input. i also thought of the exhaust purge. part of the problem is seeing it but the other part is the noise because its loud and a pretty distinct sound if your going to street race someone
Old Sep 9, 2009 | 08:18 PM
Mangled03gmc's Avatar
Baltimore Whore
Y not behind your center console
Old Sep 9, 2009 | 08:20 PM
viciousknid's Avatar
Where's the Beef?
because of his amps and subs
Old Sep 9, 2009 | 08:33 PM
schino's Avatar
word.. got a custom MDF / fiberglass console that comes a few inches away from my amp which is mounted on the back wall of the cab. itd prob work if i had the jump seat in there still
Old Sep 9, 2009 | 08:40 PM
Baltimore Whore
AHh Ok didn't know cause you said just you driver and pass seat were taken.. I say put a cooler in the bed of the truck and mount it in there, or a hollowed out tool box... That would be trick
Old Sep 9, 2009 | 08:56 PM
nonnieselman's Avatar
thats why i got a tool box
purging into your exhaust will be about the only way to keep it stealthy.. your goin to hear the purge if you put it in the frame. put it in the exhaust and when you do a few practice lauches or burnout then you can purge it and it wont be known.
Old Sep 10, 2009 | 12:54 AM
slowprocess's Avatar
Compliments of tarinitup via 2006
Thread can be found here......
https://www.performancetrucks.net/fo...ttle+under+bed
Wow......hope you guys are ready to jump into your time capsules cause even GoldenVelvet was in this post.
Old Sep 10, 2009 | 01:07 AM
Where's the Beef?
Wow. i don't know how comfortable I'd be putting the bottle in front of or behind the tire due to road debris.
Old Sep 10, 2009 | 09:11 AM
WJ MARK's Avatar
alot of guys put a bottle under the bed. I say put the purge in a normal spot and don't purge at all for street racing
