nitrious question
Old Apr 23, 2008 | 11:24 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
if it goes.....CLUNK or ........CRUNCH then you might have a G80.
you might have a G80 if your rear end looks like you ran over an IED.
Old Apr 23, 2008 | 11:27 PM
dirt track racer 81's Avatar
i thought i hit an IED when mine went out..people said i was on two wheels as i attempted to do a quick U-turn sideways
Old Apr 24, 2008 | 08:52 AM
aksz71's Avatar
glove box or the window sticker.. plus 2 i went to the chevy place were alot of my friends work and they got my vin code and ran it and it came back with everything that the truck has and it said nothing about a g80
Old Apr 24, 2008 | 08:57 AM
aaronk227's Avatar
There is a forum on here somewhere with all the codes for gears etc. But the code for the G80 is simply "G80" It will say it on the sticker in the glove box. If it doesn't have "G80" then it is an open diff, like mine was. You'll probably know though, I spun, one wheel, off the line bone stock.
Old Apr 24, 2008 | 10:34 AM
Big Red Truck's Avatar
11 Second Truck Club
Spray it from the get go!
Old May 11, 2008 | 08:08 PM
05GTO6SPEED's Avatar
most z71 have a G80. the codes are on a little white sticker in the glove box
Old May 13, 2008 | 10:06 PM
XLR8N's Avatar
It all depends on traction and what prm you are leaving the line at. If you leave the line spinning then guess what you will still be spinning...more. and unless you have a converter then you are leaving at the flash point of your factory stall which is bellow 2k, i dont recomend spraying anything under 2500rpms. Just wait till you hit the 60' mark.
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
