NEW PRODUCTS, Black Series Display Controllers.
Truck Sponsor
Well guys I mentioned in the past that we were building some new and exciting products for the nitrous world. The Black Series Display Controllers! The V and P are just 2 units so far. These units are not just gauges, but controllers as well. Clean and bright graphics added to state of the art controlling features make these units easy to read, and VERY powerful, and they both still fit into any 2 1/16 gauge area. You will be able to see what is going on with your nitrous system like never before. Each gauge has programmable inputs for 2nd pressure sensors or wideband air fuel reading. When an area exceeds a safety set point the units will disable your nitrous system. So in the case of air/fuel you can watch air fuel while driving around and but when you ready to spray if you go lean it shuts the nitrous system down.
So if you are looking for something different then just a needle moving around or bulky box type controller, then these are the gauge/displays for you.
And to make this a special for PTN the first 25 customer will receive FREE freight. Shipping to start is 3 to 4 weeks.
V = 375.00 Retail
V is the only gauge in the world that can answer that age old question that has been asked for decades, How much nitrous do I have left in the tank? Its computer processor core can calculate how much nitrous you are using and how much is left when done. It is the world's first and only gauge that is completely graphical and digital, with state of the art computer screen display. Its fully programmable system can work on any nitrous system from single stage simple systems up to dual stage progressive systems; even the purge usage is calculated. You simply program the unit to your nitrous system. V is not just a gauge its a controller as well. V can; control the heater, shut the nitrous system down; if you are running lean or low on nitrous or fuel pressure. A warning flash will let you know you have a problem and where that problem is. V will tell you, your nitrous pressure, fuel pressure or O2 reading, if the heater is on or off, nitrous level in % form, and nitrous level in color bar graph form. The full color graphic display allows you to control and monitor your nitrous system with just a quick glance at the face. You have 3 main viewing screens to choose from with just a push of the control button. Fits any 2 1/16 gauge pod. You also get to choose your bottles color with in the display.
Vcan take the place of :
1 Nitrous Pressure Gauge
1 Nitrous Pressure Shut Down Switch
1 Nitrous Heater Toggle Switch
1 Fuel Pressure Gauge
1 Fuel Pressure Safety Switch or FPSS
1 Air/Fuel Gauge (Instead of Fuel Pressure Gauge/ FPSS)
1 Air/Fuel Shut Down Switch (turns nitrous system off if running lean or rich requires a wideband with programmable output)
1 Heater Control Pressure Switch
1 Digital Bottle Weighing Scale
*Pressure sensors are required for any pressure reading, and for heater control feature to work.
P = 399.00 Retail
P is the only gauge in the world that is a progressive controller with mutli-point ramping capabilities. Its computer processor controls the nitrous system completely including the heater. It is the world's first and only gauge that is completely graphical and digital, with state of the art computer screen display. Its fully programmable system can work on any single stage nitrous system. You simply program the unit to your nitrous system. P is not just a gauge its a controller as well. P can control the heater and shut the nitrous system down; if you are running lean or low on nitrous or fuel pressure. Its a progressive controller, window switch, TPAS switch, nitrous pressure gauge, shift light. A warning flash will let you know you have a problem and where that problem is. P will display, your(nitrous, boost, fuel, or oil pressure), O2 reading, is the heater on or off, nitrous progressive level, rpm, inside or outside the window switch setting, WOT activation. The full color graphic display allows you to control and monitor your nitrous system with just a quick glance at the face. You have 8 main viewing screens to choose from, with just a push of the control button. Fits any 2 1/16 gauge pod.
Progressive controller (time or rpm based)
RPM window switch
Wide-Open-Throttle detection when used with factory TPS or WOT switch.
Supports Fly-by-Wire TPS rising or falling
5 Point variable Progressive ramping (time or rpm based)
Shift Light
Rich l Lean Cutoff (when used with a wideband)
Air/Fuel inputs Digital or Analog
Multiple wideband capabilities
Heater controller
First gear lockout / delay
8 different Main Viewing screens.
Programmable Power UP screen and Arm screen
Multiple pressure choices
Pressure display (boost, nitrous, oil or fuel)
Micro-Solenoid Driver :
This unit is included with ever P gauge. Additional unit(s) are required, if more then 1 nitrous and 1 fuel solenoids are being use.
Small compact size fits anywhere
1 x 1.5 x .75
Water tight construction
40 amp capable
Mounting tab
Long wire leads
Easy parallel wiring
I hate it when people select black for the color of the text, I view the forum in Darkside and I have to highlight the text to read it
Im liking the top one too, may have to pick one up once I get vic jr and plate system on
Truck Sponsor
Thanks for the compliments guys, these units have been in testing now for months now. Tweeking and testing take awhile and the nitrous used for confirming the data was unreal.
I am still dizzy. lol We are working on more cooling things but these I think take the cake, they can do almost everything.
V is one of those things that the nitrous world needs but never had.
P is just freaking cool with all its options, and is the only mutli point ramping progressive that does not need a lap top to set up.
You know it can be a used as a boost gauge too.
and let you know how much water meth you have left.
Or even an air/fuel lean set up to kill the boost if using a boost controller.
Just drop a line when yall are ready for me to ship. Remember the first 25 get free freight, and a free t-shirt.
Rick
I am still dizzy. lol We are working on more cooling things but these I think take the cake, they can do almost everything. V is one of those things that the nitrous world needs but never had.
Originally Posted by TurboBerserker
Wow Rick -- Nice products! They make me wish my beast was bottle fed too!
Or even an air/fuel lean set up to kill the boost if using a boost controller.Just drop a line when yall are ready for me to ship. Remember the first 25 get free freight, and a free t-shirt.
Rick
Rick
Rick
Talk to me about the boost controller options -- and being that it's progressive, it seems like it could run the meth pump too... Which might lead to some interesting antiknock options (like detect lean and dump the meth at full pressure).
You guys are doin some crazy stuff over there!!!!!!
When yall goin to get some kindof Boost gauge with all them goodies????? Ill be first in line!!!!!!
This is just amazing!!!!
