MOUNTING THE SOLENOIDs!-
#21
OK I just went out and grabed a bracket from the shiping department. The bracket you have was made with the larger solenoids that come in the NX single nozzle kits in mind. I am going to look into making a bracket made for the guys that are running systems with the small style solenoids.
On this current bracket.You can use just one screw and bolt the solenoids down and use the other bolt hole and a washer in order to bolt it down. OR you can drill the holes needed. I think the cold fusion kits uses a nitrous and fuel solenoid that have the same size small base. The NX smallest fuel solenoid is larger and still has a larger base.
So I will have to look further into this in order to have a more universal bracket for the guys that are running the little systems. Basically we will have to offer a few different brackets.
Dave
Dave
KINGCYCLES
Oct 2, 2015 10:21 AM
DrX
Sep 29, 2015 04:31 AM
