loosing some fuel pressure
Old Mar 18, 2011 | 10:35 PM
Ender06's Avatar
Default loosing some fuel pressure
Ok. I have wet 100 shot. Seems after I turn the truck off I loose fuel pressure. Gotta let it prime twice usually to start. My fuel is just connected to the 4an fitting on the rail and I can find absolutely no leaks...it is baffelling me. Any idea?
Old Mar 18, 2011 | 10:39 PM
LS1TRUCKGUY's Avatar
Your fuel noid might be leaking. Disconnect it and put the schrader valve back in the test port and try it again.
Old Mar 19, 2011 | 09:38 AM
Swerve7rpm2000's Avatar
do you have it setup as a return style? if so u will need a check valve to keep the fuel pressure on the rails
Old Mar 19, 2011 | 11:14 AM
custm2500's Avatar
Ph.D. in HUBRIS
If you don't see a leak then it must be leaking internaly. I would guess through your fuel noid. Like said re-install your shrader valve and see if it solves the problem. If so then you need a new fuel noid.
If not then your factory fuel system is probably leaking down.
Mossyoakglock
Aug 28, 2015 12:49 PM
noproblems209
Aug 10, 2015 06:57 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
