Jets for TNT nozzles?
Old Feb 6, 2006 | 11:08 AM
BigKID's Avatar
Default Jets for TNT nozzles?
I need some jets for my single nozzle TNT PowerRing setup. I know the TNT nozzles use the same large stem as the NX jets but they are flare instead of funnel jets so what jets do I need to get?
I have also used a 1.42 x jet size formula to calcuate the size jets I would need according to TNT's dual nozzle jet chart.
100hp...50N...31F
150hp...60N...35F
200hp...72N...40F
Even though the nozzles are different, I would assume the jet charts should be similar if the same jets are used. NX single nozzle jet chart:
100hp...52N...28N
150hp...62N...33F
NX's chart uses a larger nitrous jet and smaller fuel jet across the board than my calculated TNT chart. So I presume if I get all 8 jet sizes between the two charts for 100&150 I should be able to tune a safe shot makeing somewhere between the two settings.
simman22
Jan 21, 2017 10:27 PM
natejk
Nov 15, 2016 08:05 AM
Mr. Chainsaw
Oct 18, 2015 08:00 PM
1slwgto
Oct 1, 2015 01:51 PM
Rockrz
Sep 13, 2015 12:22 AM
