Jets for TNT nozzles?
I need some jets for my single nozzle TNT PowerRing setup. I know the TNT nozzles use the same large stem as the NX jets but they are flare instead of funnel jets so what jets do I need to get?
I have also used a 1.42 x jet size formula to calcuate the size jets I would need according to TNT's dual nozzle jet chart.
100hp...50N...31F
150hp...60N...35F
200hp...72N...40F
Even though the nozzles are different, I would assume the jet charts should be similar if the same jets are used. NX single nozzle jet chart:
100hp...52N...28N
150hp...62N...33F
NX's chart uses a larger nitrous jet and smaller fuel jet across the board than my calculated TNT chart. So I presume if I get all 8 jet sizes between the two charts for 100&150 I should be able to tune a safe shot makeing somewhere between the two settings.
100hp...50N...31F
150hp...60N...35F
200hp...72N...40F
100hp...52N...28N
150hp...62N...33F
