How can you gain more than the advertised hp gain from nitrous on an N/A app?
Old Jan 12, 2006 | 05:17 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Default How can you gain more than the advertised hp gain from nitrous on an N/A app?
In this thread a guys gained a 100hp from a 75 shot. It is not uncommon to gain more than the advertised shot on an FI setup due to intercooling and all and I have heard of exact gains as the manufacturer list the gain at the wheels with their pills but never gained more. How could this be not calling BS jsut wondering if someone can explain it to me.
https://ls1tech.com/forums/showpost....72&postcount=1
Old Jan 12, 2006 | 07:42 PM
Sport Side's Avatar
His 150 shot did 143HP... I wouldn't look into it.
Old Jan 13, 2006 | 09:29 PM
Ross @ EDO's Avatar
FormerVendor
my 125 shot did 152rwhp and 208rwtq at 950psi on the dyno.
Old Jan 13, 2006 | 11:21 PM
AintNoHo's Avatar
His N.A. pull probably wasn't tuned as well as his N2O pulls. The A/F was at 13.3 and more power would be at 12.8 A/F. Also he might have been able to add more spark advance. Nitrous jets hp rating isn't that exact and usually figured around 850-900 psi. He was running 1100 psi and therefore flowing more than a 75hp shot.
Old Jan 15, 2006 | 11:02 AM
Robert56's Avatar
There are so many variables. each set up is different in many areas. Also, some companys under rate, some right on the mark, and some over rate. So really the only way to be absolute on any kit/vehicle combo is to jet it to what you want on the dyno.
Robert
simman22
Jan 21, 2017 10:27 PM
91LT16SpeedFormula
Oct 1, 2015 08:57 AM
gavin2005
Sep 13, 2015 09:04 PM
