hosing the 2500 questions
I'm a noob to the LS family, but not a noob to nitrous. I'm having some fun with my tow rig, 2500 2x4 6.0. It's stock as a rock, and I am piecing together a nitrous kit for it with leftovers from my drag car.
I'm planning on a single wet NOS fogger nozzle, 150 hp shot, 100 octane unleaded race fuel.
Will the stock ECM tune be alright for nitrous, assuming I jet the kit properly?
Do 4L80's hold up well stock, should I race it using the tow/haul mode?
TR6's @ .035 the way to go?
I've seen as big as a 100 shot on a stock tune... but its not really adviseable... get a tune, then run the 150 all day...on pump gas, no need for race fuel on that small of a shot in these things
the trans will be fine... as long as you dont have a 4LjunkE in there you're good. no need for tow-haul either, just run it as is
and the TR-6's with the out-of-the-box gap is good to go... no need to mess with it IMO...
We put a 100 wet shot on my buddies bone stock 1500hd and it dropped from the 17s to a high 15(this on a window switch set at 3000rpms). It suprised a TON of stock 1/5 ton 4x4s on the street.
I think it would be fine with the 150 shot, but I do like to push the limits from time to time.
Originally Posted by silver-mod-o
there goes slow-pro... telling ppl to commit suicide again... look kids, everyone's doing it!!!!
j/k man... you probably know plenty more about the **** than I do LOL...
We're about to see how that same truck will do with a fuddle 2800 and the 150 blast. Should be interesting......
The reason for running the 100 octane is simply insurance against detonation/knock retard. I figure another $10 in fuel for a day at the track is no big deal, I have found in the past that it has given me an additional margin of error on applications where I was not able to change the timing curve. I will probably start with a 100 shot, check for detonation on the plugs, then bump it up in 25 hp increments.
My main concern was how the stock programing strategy would effect timing advance/retard on the nitrous. I just don't want the ECM throwing tons of timing at it going down the track.
Does anyone have any proven jet reccomendations for a single wet NOS nozzle?
What is stock fuel pressure on these trucks?
Thanks so much for your input.
BTW I ran a 200 shot on a bone stock 5.0 for two years with no problems, that motor still runs fine. It's all in the tuneup
Mine is doing fine on 25* with the 200 shot and 93 octane. I ran 28* with the 100 shot and 150 shot for a LONG time. Stock fuel pressure should be around 58+ at WOT
what were you using for jetting on your 100 and 150 tuneups?
also, I don't have the ability to tune yet, what is stock timing set at before any knock retard?
What year model truck is it?
It's a 1999 6 litre. There are no single NOS fogger jetting recomendations in the sticky, only for their plate kit. I have used NX and NOS jetting combos interchangably, the only difference is NX is much more realistic on their target AF ratios, NOS just runs everything pig rich. I think I will start with a 55 N and a 28 F. I am using the large NX solenoids, so the orfice restriction is going to be different anyways. I will hopefully just be able to play with jetting and see what ET's the best.
What is the best way to tap into the fuel system?
I will post 1/8 mile times on Thursday in case anyone cares.
