Help me get in the 6’s
Old Jan 22, 2022 | 08:40 PM
06murder's Avatar
Default Help me get in the 6’s
06 Silverado with a 5.3 with 224/230 on 114 on 200 shot, 4l80e 3600 stall with 4.10 has went 7.13 at 94 cutting 1.57 60ft. Need to get in the 6’s before March!
Old Jan 23, 2022 | 02:11 PM
RDF1's Avatar
DuNnO
5 Year Member
Is it a LM7? With 706 or 862 heads?
this 200 shot on 93 octane?
Old Jan 23, 2022 | 07:24 PM
06murder's Avatar
862 heads lm7 yes 93
Old Jan 24, 2022 | 11:12 AM
BigKID's Avatar
With the metrics in the op, it either needs to pick up on the 60' or make more power on top end. The 60' is within range of what I would expect for the setup dependent of weight. The mph seems a bit low for the et/60' though so I'd focus on that. Lots of variables for that setup on tune, induction and exhaust that could affect it falling of on the top end.
Old Jan 24, 2022 | 01:54 PM
Bgbldodge's Avatar
E85 and more timing and spray?
Old Jan 24, 2022 | 05:27 PM
Beatdown Z's Avatar
Laid Back
Sounds like it’s running great for the mods you have listed. Since you’re the one behind the wheel, where do you think it could use improvement?
Old Jan 24, 2022 | 06:50 PM
RDF1's Avatar
DuNnO
5 Year Member
Do you have a recent time slip so we can see what the numbers are?
Old Jan 25, 2022 | 11:07 PM
06murder's Avatar
I have a true duel exhaust in spare room just haven’t install it idk how to post pictures on here reaction .7667 60ft 1.5785 330ft 4.5695 1/8 7.1382 mph 94.44 I want 6 sec pass I have 250 jets just haven’t try them out yet, wanna just jump to a 300 jet for truck wars if it blow oh well I have a forge 6.0 on engine stand!but I think it has to do will suspension! Front is stock never messed with it, rear is mean leaf with the over load with 2” shackles with cal trac with 3 hole I’m on the bottom hole with 28” 10 17 hossiers slicks
Old Jan 25, 2022 | 11:10 PM
06murder's Avatar
I was on the stock 78 mm tb with tabs intake now have ls3 tb on it now
Old Jan 26, 2022 | 12:29 AM
06murder's Avatar
I have 13/4 long tube and 3” y pipe in single 3” with borla muffler xr1 I have I made a 4” cai, with 4” air filter, I know something choking it down or slowing it down, can’t get my head around it.
