Going with spray only
Old Jan 11, 2010 | 05:02 PM
ONLYA4.8L's Avatar
Default Going with spray only
I have decided to go with n2o only... Wondering if my cam is good enough for it and curious if my fuel system will b good enought for a 200hp dry or if I
should continue to run a wet... Would it be worth it to port the heads? My mods r in my sig..
Old Jan 11, 2010 | 07:04 PM
aksz71's Avatar
looks good too me , i would prolly get a stand alone fuel system for that big of a shot imo. and i would stay with wet but if you wanna do dry then do that if its what you want.
Old Jan 11, 2010 | 08:36 PM
ONLYA4.8L's Avatar
I wanna get most outta it but be safe... Also gettin arp to hold the heads down.. What abt porting think it will be worth it to port em
Old Jan 12, 2010 | 10:57 AM
aksz71's Avatar
maybe eventually but if you just have the money to spend then go for it. but all your mods plus a 200 shot your not going to notice the difference from porting the heads imo
Old Jan 12, 2010 | 12:03 PM
ONLYA4.8L's Avatar
Good to know... I think ill keep the wet shot
Old Jan 12, 2010 | 01:33 PM
Mangled03gmc's Avatar
Baltimore Whore
Yah the wet shot is the way to go, over the dry, when running a shot that big...
Old Jan 12, 2010 | 02:29 PM
ONLYA4.8L's Avatar
Was lookin at the other thread about n2o plates... Would it b worth it
Old Jan 12, 2010 | 02:53 PM
aksz71's Avatar
when i had spray on mine i had a nozzle had no problem with it at all. i wanted a plate kit cause i nice setup and looks under instead of having a nozzle sticking out of the air tube, but if you got the money to blow yes why not. but if your on a budget or whatever then nozzle will be just as good.
Old Jan 12, 2010 | 03:04 PM
BlackGMC's Avatar
Resident Retard
Wouldn't a 200 DRY shot require some pretty LARGE injectors???? What size injectors do you have now??
Old Jan 12, 2010 | 04:19 PM
ONLYA4.8L's Avatar
I have 42lb... I decided to stay with the wet... Dry is too risky... I wanna keep the n2o **** hidden that's why I was curious about a plate.. But ill stick with wet fogger and just put the nozzle through the bottom..
