fuel upgrades for nitrous
Old Jul 10, 2014 | 08:39 AM
Nitrous Express's Avatar
Former Vendor
Originally Posted by brizzle815
I'm still unsure about my fuel set up.
I know now I'm good on my current injectors.
I'm only wanting 150 shot
I'm wanting to upgrade fuel pump for security.
How much is a stock fuel pump pressure?
Should I go with in line pump and keep stock pump?
Should I go with in tank?
Stock fuel lines ok? Do they need to be bigger
Bosch or walbro pump?
I'm wanting a fuel pressure switch for the nitrous? How do these mechanicaly work?
If I get fuel pressure gauge should I monitor at pump or at switch?
Sorry for the noon questions I just want to do this nitrous right
Thanks
Stock fuel pressure should be 55-58psi at WOT.
In-line Pumps are a popular option.
Stock fuel lines are fine.
Either pump would be a good option.
The way a fuel safety switch works is just like an on/off switch. if it has pressure it is on, if it drops below the pressure you set it to (user adjustable) the switch is off
Old Jul 10, 2014 | 11:24 AM
gamble686's Avatar
Get an AEM 320lph should be plenty for your setup. The in tank pump should be the way to go.
Rafe19
Oct 18, 2016 12:27 AM
slowlsx
Aug 13, 2015 08:28 PM
MS3Z
Jul 30, 2015 06:17 PM
4B11T
Jul 13, 2015 03:48 PM
