fuel upgrades for nitrous
So I have been doing little research on running nitrous in my truck. I'm leaning towards a 100 dry shot.
Can I go ahead and upgrade fuel pump and injectors before the nitrous. As funds are available buy a nitrous kit? Currently running 31lb injectors. Do I need to change maf? Stupid question! Will I need to have truck returned just for fuel upgrades? I know need tune with the nitrous. Thanks guys for any tips and advice |
You'll need the to retune for the injectors.. Easier to just do a wet shot.
x2 on that and no need to change your maf
A Wet shot is much simpler and more consistent and it wont run terrible NA with a nitrous tune. You can get a wet system for right at $445. Pm me for more info
Originally Posted by Nitrous Express
(Post 5226461)
I'm still unsure about my fuel set up.
I know now I'm good on my current injectors. I'm only wanting 150 shot I'm wanting to upgrade fuel pump for security. How much is a stock fuel pump pressure? Should I go with in line pump and keep stock pump? Should I go with in tank? Stock fuel lines ok? Do they need to be bigger Bosch or walbro pump? I'm wanting a fuel pressure switch for the nitrous? How do these mechanicaly work? If I get fuel pressure gauge should I monitor at pump or at switch? Sorry for the noon questions I just want to do this nitrous right Thanks |
Originally Posted by brizzle815
(Post 5228562)
I know now I'm good on my current injectors. I'm only wanting 150 shot I'm wanting to upgrade fuel pump for security. How much is a stock fuel pump pressure? Should I go with in line pump and keep stock pump? Should I go with in tank? Stock fuel lines ok? Do they need to be bigger Bosch or walbro pump? I'm wanting a fuel pressure switch for the nitrous? How do these mechanicaly work? If I get fuel pressure gauge should I monitor at pump or at switch? Sorry for the noon questions I just want to do this nitrous right Thanks EDIT: heres there link. already comes with all an hoses from tank to the pump to the regulator. and mounts in the spare battery tray http://www.nitrousexpress.com/15003-...-gasoline.html |
Not trying to kill you Jake but a stand alone for a 150 shot would be lots of money spent for no real good reason.
A 150 with a stand alone makes plenty if since to people who don't like to remove brakes and build home made throttle bodies.
You can choose the fuel you want to supplement with and it doesn't tax your main fuel system so it has a better chance of being consistent and easier to tune on the fuel side, especially if the pressure is adjustable. |
Originally Posted by custm2500
(Post 5228863)
