Fuel Pressure Safety Switch
Old Oct 21, 2010 | 02:30 AM
Steve-O-08's Avatar
Default Fuel Pressure Safety Switch
I was reading on LS1Tech and came acrossan article on adjusting a FPSS and most of the replies said that running a FPSS is a waste. I don't know why it would be. Does anyone else on here feel the same way? and is there a way to properly adjust them?
Old Oct 21, 2010 | 01:12 PM
fastrt's Avatar
11 Second Truck Club
I just run a fuel pressure gauge and keep an eye on it. I had one on my old setup, but guessed at the adjustment. I am sure daves can adjust one for you if you buy one from them. my fpss is still in my tool box, i would run it, but I dont have the room with the new stuff.
Old Oct 21, 2010 | 05:48 PM
custm2500's Avatar
Ph.D. in HUBRIS
Throw it in the garbage!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If it is the thread I posted in follow my advice to a T.
Remove it,aim and kick it at your most hated neighbor's house. Be happy anything short of that is a complete and total waist of time.
Old Oct 21, 2010 | 06:26 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
and why is that Custm2500?
Old Oct 21, 2010 | 08:06 PM
custm2500's Avatar
Ph.D. in HUBRIS
The cause nothing but problems. Such as the OP is looking to adjust it. Apparently it isn't set right or some issue is becoming of it.
They don't read right half the time and cut your nitrous out wile you have perfectly good fuel pressure. It is another set of connections to worry about and potentially a good length of tire you need to add(6-30"). Virtually no one runs them and the only people who will tell you to run them is the manufacture just to cover there butt. Long before I learned on forums that they are worthless I removed the one on my probe(10 years ago) because of issues. I never installed one on my truck for two reasons, the used kit I bought didn't have it(previous owner threw it away) and secondly I am not telling other to not use one wile I have the piece of **** on my own truck.
If you want a reliable and usefully tool to verify you aren't going lean a Wide band gage and shut down switch is what you want and need. It helps you dial in your A/F ratio and will shut the nitrous down if anything gets too far out of wack. They are $200ish new and up. Not really needed but a nice addition to have. I don't have one and have no intentions of buying one any time soon.
Old Oct 21, 2010 | 08:56 PM
fastrt's Avatar
well.....it does, and will work if you set it right and it could save your motor if your pump fails. all you gotta do is rig up a $50 adjustable air pressure apparatus and set it to 50 psi...lol. I am not "as" against them as custom2500 is, but .....to each his own.
Old Oct 22, 2010 | 08:37 AM
trever1t's Avatar
I have one and have never had any issue, as of yet.
Old Oct 22, 2010 | 07:05 PM
custm2500's Avatar
Ph.D. in HUBRIS
I would remove it before it does! Going to save you some grief down the road. If it doesn't you will be the 1% that it doesn't cause problems for.
Mossyoakglock
Aug 28, 2015 12:49 PM
noproblems209
Aug 10, 2015 06:57 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
