Fittings help please.
Old Dec 1, 2009 | 10:00 AM
lownslo's Avatar
Default Fittings help please.
I have a -4an to 1/8 npt that i want to run a .100 pill in. This will act as a restrictor for my oil feed to the turbo. I need to put the jet in line, the 1/8 will go directly into the turbo so it will have to be on the -4an side but i can't find the correct fitting. Can someone help me? I guess i don't know what to ask for?
Old Dec 2, 2009 | 11:00 AM
Nick@HSW's Avatar
FormerVendor
That's not gonna work. The jet acts as the 37* flare required to seat with the hose. What you can use are one of these...its the fitting we use on our plate systems to hold the jet. One side is 1/8NPT and the other is drilled to except jets and a -3 hose. We can also put a 3AN b-nut onto a -4 hose if that's the size you need for flow.
They're the fittings on the ends. We generally don't sell them separate but give us a call and we'll help you out.
Nick
Old Dec 2, 2009 | 11:30 AM
thunder550's Avatar
High on diesel fumes
I ground the flare off on the AN side of my adapter and put the nitrous jet in there, worked ok for me.
simman22
Jan 21, 2017 10:27 PM
FlowmasterMufflers
Nov 24, 2015 01:00 PM
SloSVO
Sep 12, 2015 06:56 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
LSX-81-SIERRA
Sep 5, 2015 02:51 PM
