First Time Setup
Old Oct 11, 2015 | 12:03 PM
GM1697's Avatar
Default First Time Setup
If I were to be looking to do a simple nitrous setup (100-150shot) would this get the job done? and would I need anything else?
Proton Plus Kit with Bottle
PROTON PLUS NITROUS SYSTEM W/ 10LB BOTTLE
TPS WOT/Window Switch
NX DIGITAL RPM WINDOW SWITCH (Now for all ignition types - No RPM chips required)
Old Oct 11, 2015 | 12:15 PM
Jake75's Avatar
yup that will take care of it! make sure you pull some timing out of your tune....typically 2 degrees for every 50hp you plan to spray!
Old Oct 11, 2015 | 04:43 PM
Fast6.3's Avatar
to pull timing the lnc2000
Old Oct 11, 2015 | 05:28 PM
GM1697's Avatar
Timing will be done thru an alternate tune I'll load at the track.
Old Oct 16, 2015 | 04:36 PM
GRRR65GTO's Avatar
You cheater you took the easy way out to make power
Old Oct 17, 2015 | 08:55 PM
GM1697's Avatar
The truck daily's perfect with the current power, just need something extra to keep up with you and diesels at the track.
Old Oct 19, 2015 | 09:20 AM
Nitrous Express's Avatar
Former Vendor
That will make for a great setup to start with!! A lot of people like to add a bottle warmer, pressure gauge and purge kit later on down the road.
Old Oct 20, 2015 | 11:43 AM
GM1697's Avatar
Do forum members get any discounts?
Old Oct 21, 2015 | 03:42 PM
XBlackXCheavyX's Avatar
I've been eye balling this kit to for some cheap power until I funds allow f/I. Let us know if you pull the trigger.
Old Oct 25, 2015 | 02:53 AM
megabuddys's Avatar
Nitrous express makes nice stuff, but I recommend the ZEX wet kits. 3 wire hook up, built in programmable TPS WOT switch. Super easy to installl and very reliable. I have probably installed 20 of these kits. If you can afford it just get a bottle heater right away. I do not recommend the ZEX bottle heater, its slow and doesnt get very hot. These work very well below.
https://www.dynotunenitrous.com/stor...p?idproduct=17
