difference in noids?
well, my buddy said he would let me use his n.o.s. kit, but he said the fuel noid will not open at the fuel pressure levels of a fuel injection system, and that he has to run a regulator between his dedicated fuel pump and the solenoid so it works properly on his carberated application.... i would hate to find out the hard way.....
anyone elso know of a problem with this???
sponsors???
sponsors???
Originally Posted by goshawk23
my old old old NOS fuel noid came from a carb kit. i hooked it up as i did my dynotune and harris speed works noids. never a problem. pressure isn't what opens these noids it's the current
before you do if you are using used noids man check those things. make sure they click when you put a 9v batt to them. also it don't hurt to take them apart and look. my first noids were NOS branded but the guy i bought them from took the damn thing apart and removed a rubber 0 ring gasket. well, thats what i put back in there to seal it but protect yourself. check them out
they are in good working order. the noids are only about 6 months old and are on my buddies car right now. they probably dont have more than 50-75 passes on them. i will check them just to make sure. thanks.
