difference in noids?
Old Aug 16, 2006 | 06:24 PM
LS1TRUCKGUY's Avatar
Default difference in noids?
is there a difference between the N.O.S. (the brand) solenoids that come in carburated kits and fuel injected kits?
Old Aug 16, 2006 | 09:14 PM
goshawk23's Avatar
Truck addict
not that i am aware of.
Old Aug 16, 2006 | 09:55 PM
well, my buddy said he would let me use his n.o.s. kit, but he said the fuel noid will not open at the fuel pressure levels of a fuel injection system, and that he has to run a regulator between his dedicated fuel pump and the solenoid so it works properly on his carberated application.... i would hate to find out the hard way.....
anyone elso know of a problem with this???
sponsors???
Old Aug 16, 2006 | 10:39 PM
goshawk23's Avatar
Truck addict
my old old old NOS fuel noid came from a carb kit. i hooked it up as i did my dynotune and harris speed works noids. never a problem. pressure isn't what opens these noids it's the current
Old Aug 17, 2006 | 06:21 PM
thats all i needed to know. thanks a lot. hopefully i get some new times with the nitrous & tune this weekend
Old Aug 18, 2006 | 12:17 AM
goshawk23's Avatar
Truck addict
before you do if you are using used noids man check those things. make sure they click when you put a 9v batt to them. also it don't hurt to take them apart and look. my first noids were NOS branded but the guy i bought them from took the damn thing apart and removed a rubber 0 ring gasket. well, thats what i put back in there to seal it but protect yourself. check them out
Old Aug 18, 2006 | 05:53 PM
they are in good working order. the noids are only about 6 months old and are on my buddies car right now. they probably dont have more than 50-75 passes on them. i will check them just to make sure. thanks.
twake_410
Apr 14, 2016 09:58 PM
wickedRCSB
Oct 30, 2015 09:45 PM
Staggered 02
Oct 9, 2015 05:19 PM
gmcyukon
Oct 5, 2015 06:20 AM
sTNT971
Sep 26, 2015 06:27 AM
