Diesel nitrous
Old Nov 2, 2013 | 08:57 AM
hondarider552's Avatar
Default Diesel nitrous
Just installed my Zex diesel nitrous system in my single cab, it has the "smartbox" under the dash, one wire that taps into throttle position sensor. I installed the box correctly, triple checked the wiring but ran into issues.
First I followed the destructions, programmed the Zex box for WOT and idle with master arm in ON. Turned master off with ignition still on per instructions, rearmed system, and tested operation multiple times, never failed to spray at WOT. I turned the truck off, went to dinner, put a baby jet in it, and retested... this time as soon as I turned the master switch to arm, the solenoid clicked like crazy on and off at idle... could duplicate this over and over...
Has anyone ran into this issue? I didn't use butt connectors on anything, soldered everything, correct wire is used for TPS.... (light blue), kinda out of ideas.
Don't have any experience with automated nitrous controllers so figured I'd ask.
Bought this kit>
ZEX
thank you for any help.
Old Nov 2, 2013 | 08:05 PM
custm2500's Avatar
Ph.D. in HUBRIS
Your first mistake was buying a zex kit. My guess is that there is something wrong with the kit. Hopefully you can return it a get a better system from nitrous outlet or another sponsor.
Old Nov 3, 2013 | 01:02 AM
I totally removed the whole zex system, and going to wire in my own using a momentary push button, using the master switch that was included in the zex kit.
Old Nov 3, 2013 | 06:13 AM
custm2500's Avatar
Ph.D. in HUBRIS
Your better bet is to return the system but good luck if you keep it
Old Nov 3, 2013 | 10:37 AM
walledition's Avatar
We installed a zex kit on a harley truck once and exacly the same thing happend, i wouldnt trust that same kit again but my friends insisted and he still uses it, works good now after it did that a couple of times
Old Nov 3, 2013 | 07:25 PM
I will be calling Zex tomorrow to get a new box, but will not be using it.
Already hooked it up to my horn relay
Old Nov 6, 2013 | 06:04 AM
Got it figured out.
I tapped into the wrong TPS wire on the truck. The diesels (not sure about gassers) use 4 wire setup for the TPS, none read .50-4.5 volts or something along those lines.. I had to use the one wire that read the most about of voltage difference.. Zex told me it was the light blue wire.. it was actually the dark blue. Doh.
Setup is working normally.
Old Nov 8, 2013 | 07:04 PM
.070 jet hits pretty hard from a dig
Old Jan 25, 2014 | 07:32 AM
Nitrous has been working great since my last post, no more issues. Still have the .088 pill in it and she likes it.
Old Jan 25, 2014 | 01:49 PM
Choda's Avatar
get some vids up
