did some NX testing on a 5cyl colorado
Old 02-17-2012, 09:34 AM
nonnieselman's Avatar
Dont let off till you pass the finish line.
That looks like a fun little truck.
Old 02-17-2012, 12:38 PM
Three6GMC's Avatar
Badass now try that 100 shot on a Colorado with the 5.3 and 4wd bet it would haul ***!
Old 02-17-2012, 02:37 PM
Former Vendor
NitrousExpress's Avatar
Did you have a question on the kit? As far as spraying through shifts its up to you if you let off the nitrous then get back into it after it shifts then you are putting more strain on the engine rather than the transmission. I personally don't recommend letting out through the shifts but it is up to you
Originally Posted by hondarider552
Any update on this? Im looking into the Proton kit very seriously for my 3.5 Colorado..
Forget the noob question, but hwy no spraying through the shift? My 4L60 has been modded, and the truck has been lightened up a bit.
Old 02-17-2012, 10:19 PM
CC05's Avatar
I ran over a 100 bottles through my RCSB 2.8 and it held up all the way to a 125 shot, and was still sold in great working condition. Ran it mostly on a 50-70 shot, but I upped the shot every so often. Proton Plus kit, 10 lb. bottle between the seats, and the picture is above on Page 1 where I just tapped the Shark Nozzle into the K&N. It all started on a bone stock tranny and was fine there even before upgraded. A set of TR6's and a good tune, and it was running just fine, through shifts or not. I switched it all up a million times, but finally ended up doing an 8.60 1/8th on a 125 shot, no window switch, 93 octane, plugs, shift kit, 3.73's out back, K&N, gutted manifold, full exhaust with Magnaflow, e-fan, Walbro 255, radials, and an agressive tune. Very simple, cheap setup that wasn't complicated. Actually made a good street ride.
Avalanche2002
11-30-2015 07:31 AM
BlownHD
10-03-2015 12:24 PM
jfuegner
09-22-2015 12:30 PM
Dezmo
09-09-2015 02:09 AM
the owl
09-04-2015 04:09 PM
Quick Reply: did some NX testing on a 5cyl colorado
