custom sneaky pete
Old Mar 25, 2007 | 09:22 AM
cablebandit's Avatar
9 Second Club
LOL..Quicksilverado and the ole rag in the i/c trick. I think he did it to see if less flow would give the air more time to be cooled
Old Mar 25, 2007 | 10:36 AM
SSSBLKOUT's Avatar
yeah, thats the idea.
Reverse routing... 1 nozzle (fuel/n2o), mounted at the mouth of the TB, screwed to the bottom of the intake tube, with a slight angle upward. Snake the lines through the intake tubing, , pop them out right before the MAF, wrapped in either corrugated plastic or vaccuum line, and quickly into something that would resemble a relay box and contain the solenoids, windowswitch, etc...
As for the bottle, maybe mounted to a framerail, or under the gutted glove box??
I think that it'd work.
Old Mar 28, 2007 | 11:14 AM
SSSBLKOUT's Avatar
no one else has any thoughts on a sneaky pete?
Or are you just not giving them up?
Old Mar 28, 2007 | 11:19 AM
Lurius's Avatar
A nitrous sponsor here recently posted an ls6 intake with the nozzle under the intake manifold. Look for that, would be badass on a truck manifold. Then just spray the lines flat black and run them down the side of transmission, then back over to rail, install a small bottle here and your golden.
-Lurius
Old Mar 28, 2007 | 11:23 AM
CHEVRACER83's Avatar
HAHA I HAD A BODYSHOP RECENTLY WHO WAS FIXING A BRAND NEW C6Z06 AND HE COULDNT FIGURE OUT WHY IT WOULDNT START.
TURNS OUT HE LEFT A SHOP RAG IN THE TB AND PUT THE INTAKE BACK ON...
THE TECHS HAD A FIELD DAY WITH HIM....
Old Mar 28, 2007 | 11:35 AM
SSSBLKOUT's Avatar
-Lurius
Wouldn't that require a nozzle for each cylinder?
Old Mar 28, 2007 | 12:25 PM
Lurius's Avatar
yea, i think it had'm, unsure. may have been a single near the tb?
-lurius
Old Mar 28, 2007 | 02:33 PM
ZZebes's Avatar
Nitro daves has the moneymaker intake that is completely concealed. he posted it here a couple of days ago and it works with a truck intake. I think its a wet sytem with shots from 35-300
https://ls1tech.com/forums/showthread.php?t=384727
Linky
Old Mar 28, 2007 | 03:42 PM
slowprocess's Avatar
Originally Posted by '89ChevyMadneSS
what about the guys with the nozzles plumbed into their cold airs and such??
That's a dry shot. There is no fuel line/noid being used on a dry shot. The maf is telling the injectors how much fuel to add to the nitrous. On a wet shot, you're pulling fuel from your fuel rail and its mixing with the nitrous as it comes out of the nozzle.
