Custom Intercooler Spray Bars.
Old Oct 19, 2012 | 10:10 AM
NitrousExpress's Avatar
Former Vendor
Default Custom Intercooler Spray Bars.
I figured that I would share with you guy a intercooler sprayer that we just finished up for a customer.
We can built these thing so any shape and size that you may need, so if you are ever in the market for one give me a call and I can get you setup.
Trey
Old Oct 19, 2012 | 11:12 AM
JoeyGC5's Avatar
Looks good.
How is Mr Wood doing these days?
Old Oct 19, 2012 | 11:48 AM
nonnieselman's Avatar
Does one run a jet with something like that?
Old Oct 19, 2012 | 11:50 AM
Neal@NitrousOutlet's Avatar
FormerVendor
open flow. no need for a jet. You want to get the most bars as possible
Old Oct 19, 2012 | 04:01 PM
Former Vendor
There is no need to run a jet we use one of our smaller solenoids to restrict the flow down, it uses 150 hp worth of nitrous when it is being sprayed.
Trey
Old Oct 21, 2012 | 11:09 AM
custm2500's Avatar
Ph.D. in HUBRIS
At first this seems to make sense. But then you realize that you could spray the nitrous into the engine and make 150 hp not the 20 it will gain from cooler temps. But honestly why not just put a 25-50 shot into the engine since it will require very little tune adjusting vs. cooling the inter cooler?
Old Nov 13, 2012 | 12:41 PM
kush killer's Avatar
wondered the same thing myself
Old Nov 13, 2012 | 01:04 PM
Unless someone uses it where Nitrous cant be used as an power adder.. Come classes are setup like that..
Old Nov 13, 2012 | 01:11 PM
^^^ makes sense.. was thining of running one of these but, pretty sure ill jsut runnin a 50 whole shot
Old Nov 14, 2012 | 12:11 PM
sand man's Avatar
why not both , 150+25
