Custom Intercooler Spray Bars.
1 Attachment(s)
I figured that I would share with you guy a intercooler sprayer that we just finished up for a customer.
We can built these thing so any shape and size that you may need, so if you are ever in the market for one give me a call and I can get you setup. Attachment 127623 Trey |
Looks good.
How is Mr Wood doing these days? |
Does one run a jet with something like that?
open flow. no need for a jet. You want to get the most bars as possible
There is no need to run a jet we use one of our smaller solenoids to restrict the flow down, it uses 150 hp worth of nitrous when it is being sprayed.
Trey |
At first this seems to make sense. But then you realize that you could spray the nitrous into the engine and make 150 hp not the 20 it will gain from cooler temps. But honestly why not just put a 25-50 shot into the engine since it will require very little tune adjusting vs. cooling the inter cooler?
Originally Posted by custm2500
(Post 5011554)
wondered the same thing myself |
Unless someone uses it where Nitrous cant be used as an power adder.. Come classes are setup like that..
^^^ makes sense.. was thining of running one of these but, pretty sure ill jsut runnin a 50 whole shot
why not both , 150+25
