Couple of Qs
Old Jul 18, 2007 | 04:32 PM
sk8rshorty's Avatar
Default Couple of Qs
Hey guys i got a few questions that i just couldnt seem to find when i searched but i coult be wrong so if this has been asked please show me the link
Putting a 100 wet shot from HSW on my truck (5.3, RCSB, 4.10s, LTs True Dual Exhaust, Nelson Tune)
Blowdown tube?
i know that u need one if u have the bottle in the truck passenger compartment but it will be placed in my bed. My bed is enclosed with an ARE LSII tonneau cover, do i need one for that or is only when it is in the passenger compartment or should i just be safe rather than sorry?
Anything else Recomended?
I am running the HSW Wet kit with 100 shot jettings should i use get anything else? i do not plan on spraying often basically as soon as i install it and at the track to see what i run and then maybe a few other times
Any predictions on Times?
when my truck was completely stock (just about 1000 miles on it and my 5.3 truck came stock with the 4.10s) i ran the best of 15.74 in a warm september day at englishtown NJ anyone have any predictions as to what i will be running with this setup i have people theorizing that i should come close to knocking on 13s but i think i would be happy with a low to mid 14
Thanks again and like i said i have used the search tool and could not find these answers but i could be mistaken so if it was asked before please show me. the blow down tube question was asked before but usually for inside the passenger compartment and i dont know if the others had an enclosed bed
Old Jul 18, 2007 | 04:51 PM
.T.'s Avatar
.T.
Start here... then back out to all the stickys.
If your bottle blows it's going to ruin your paint, if you care.
IMO you won't drop 1.75 with a 100 shot in a stock 5.3 but I'd love to see you prove me wrong. Get 'er done!
Old Jul 18, 2007 | 05:11 PM
sk8rshorty's Avatar
thanks for the info i think i will get the blow down tube and probably a window switch
how much do u think i will drop with the 100 shot? i also have the long tubes and the tune now so i figure thats good for .2-.5 faster
Old Jul 18, 2007 | 05:46 PM
99Silverado5.3's Avatar
FWIW, my friend on a mid high 80 degree (very humid) day knocked 2.8 seconds off his 1/4 time on a 150shot. Should be high 14's all motor and in the 13's with your mods spraying first gear with decent traction on a 100 shot. I have less mods and did it on a 100 shot in my ex cab. Also, don't worry about the blowdown tube. If I were you, don't get a window switch and wire it to run off a button and just let off right before the shift, then get back on the button after it shiftd..that is what I do.
Old Jul 18, 2007 | 05:55 PM
Forgot to add. Also, get a bottle heater and a nitrous filter. You will also HAVE TO get and install some NGK TR6 spark plugs.
I have Wheatley Tune, 4.10, no cats, bullet muffler, and 100 shot. Did a 13.8 spinning.
Old Jul 19, 2007 | 02:26 AM
RedHot04's Avatar
Whew.........Just do it & make sure a/f is on target you'll be fine for the track.
Old Jul 22, 2007 | 01:29 AM
03SSS-07TBSS's Avatar
NOS is like crack! You can't just hit once.
AdaMax
May 16, 2016 11:35 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
Infernohoe
48
Oct 2, 2015 10:25 PM
The_W
Oct 1, 2015 02:35 PM
old motorhead
Sep 29, 2015 08:22 PM
