can you mix
Old Jun 3, 2007 | 10:13 PM
mkufamous's Avatar
Default can you mix
hello, i am just wondering if you can add a nos kit with a water/metholo kit, i have a snow performance kit and been thinking of adding a nos to my suv.
i am wondering if possible is there anything special i need to consider, special tuning, additional parts, for safety and maintaince sake, any infro would be greatly appreicated.
Old Jun 3, 2007 | 10:47 PM
Phantom's Avatar
11 Second Club
yes you can do it, yes you need "special" tuning, yes you'll need additional parts...demanshu is runnin a setup like this...
what supercharger do you have? trevor1t added a NITROUS kit to his radix and ditched his meth kit i believe. search those two guys and see what you think
Old Jun 3, 2007 | 10:51 PM
04Denali's Avatar
I am sure Bill is still using Meth
Old Jun 3, 2007 | 10:54 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Uh, lol, I didn't ditch the meth. I run meth with an Alky Controll kit and add a small shot of nitrous with a Nitrous Dave's wet kit for the track. The Meth is great for daily driving, the nitrous an added shove when I need it.
I chose wet because I didn't want to alter the tune for my daily driver. Flip a switch and more fuel is added simultaneously with the shot.
Fuel pressure saftey swith
Window switch
Old Jun 3, 2007 | 10:55 PM
Phantom's Avatar
11 Second Club
ok i wasn't for sure...but the guys question has been answered...it can be "mixed"
Old Jun 3, 2007 | 11:26 PM
mkufamous's Avatar
Window switch
does the switch only acitves the nos and the metholo shuts off or does it work together, because my snow performance will automatically shots when i hit 3000 rpms
Old Jun 3, 2007 | 11:34 PM
2004SSS's Avatar
im going to be running meth and alky too. but i think most who run them will have the methanol and the nitrous at the same time. i thought of something though. could say a 150 shot of nitrous along with methanol/water mix be harmful? is it possible to have the nitrous freeze the meth/water? i have a spray bar in my vic jr so its only a few inches from the cylinders . the time it would have to freeze is very short. the meth will be spray about 1 ft from the tb since im running dual nozzle's and i want the iat sensor to be after them so i can see the cooling effect in my logs. sorry for the hi jack but its a good topic for it.
Old Jun 3, 2007 | 11:44 PM
trever1t's Avatar
Right, the meth is on when i have over 3lbs boost, all the time. The nitrous (don't say nos) is on with the switch.
I run staright Meth so I dont think even a large shot of n20 is going to freeze and I doubt a 50/50 would either but once it hit the intake manifold it's going to gas even if it did.
Old Jun 4, 2007 | 12:15 PM
mkufamous's Avatar
thanks, i called dave at nitrous and we talk about which kits would apply to my application and we recommend that i purchases a wet system with a window switch, also i called snow perfomance and they recommend that you have the nitrous spray before the metholo,
i was wondering do you have a wet system too with a window switch, if not how did you get the tunning down with a direct switch shot. if that makes sense
Old Jun 4, 2007 | 12:39 PM
trever1t's Avatar
I pay somebody to do my tuning, he is pretty good at what he does, too. As far as spraying before the meth, I don't know if that is even possible. My system is activated by a WOT switch (under pedal) and the window switch, spraying from 3000 rpm.
The Meth starts at 3lbs which would probably be as soon as my foot hits the pedal!
