50 or 75 shot?
50 or 75 shot?
Has anybody ever herd of someone blowing there motor on this amount of nitrous? All my mods are in my sig and I have my truck tuned. I want to spray a 50 or 75 shot without a retune I'm just afraid something will blow? Truck has 77,000 miles on the clock if that helps and it's a wet system.
i agree with all of the above i have ran nitrous on a couple of set ups and if i was you i would at least run a 100 shot and i am telling you from experience you can run 150 take 4* timing run tr6 plugs and run it off of a window switch and it wont hurt a thing. i had my 4.8 full bolt on with 220 224 cam with a 150 shot and the only thing that happen to that motor was i had an ls6 spring get week and had some piston valve action and that motor had 160k plus
id run no less than a 100 shot IMO... and if you already have a tune contact the tuner too see were the timing is to find out if that shot will be fine at the timing that have it at... i run a 125 shot on stock tune well everything is stock not one problem ... but do that and get some tr6's and go spraying away
