50 or 75 shot?
Old 03-05-2009, 11:08 PM
slowlsx's Avatar
Default 50 or 75 shot?
Has anybody ever herd of someone blowing there motor on this amount of nitrous? All my mods are in my sig and I have my truck tuned. I want to spray a 50 or 75 shot without a retune I'm just afraid something will blow? Truck has 77,000 miles on the clock if that helps and it's a wet system.
Old 03-05-2009, 11:12 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
depends on how much timing you have in it already.
Old 03-05-2009, 11:38 PM
slowlsx's Avatar
what timing would be needed to be able to run a 50? for a safe run
Old 03-05-2009, 11:45 PM
1_fastsilverado's Avatar
I heard they like to pull around 1* for each 50hp shot. Also I've read that you don't really feel anything under 100 shot, so if you are getting retuned I'd go bigger
Old 03-06-2009, 12:06 AM
nonnieselman's Avatar
I agree
100 shot and TR6 plugs... vola, instant addiction.
Old 03-06-2009, 01:57 AM
dirtychevy99's Avatar
i agree with all of the above i have ran nitrous on a couple of set ups and if i was you i would at least run a 100 shot and i am telling you from experience you can run 150 take 4* timing run tr6 plugs and run it off of a window switch and it wont hurt a thing. i had my 4.8 full bolt on with 220 224 cam with a 150 shot and the only thing that happen to that motor was i had an ls6 spring get week and had some piston valve action and that motor had 160k plus
Old 03-06-2009, 07:15 AM
aksz71's Avatar
id run no less than a 100 shot IMO... and if you already have a tune contact the tuner too see were the timing is to find out if that shot will be fine at the timing that have it at... i run a 125 shot on stock tune well everything is stock not one problem ... but do that and get some tr6's and go spraying away
twake_410
04-14-2016 09:58 PM
Slammed silverado
09-28-2015 06:14 PM
Closer_2001
09-16-2015 11:46 AM
94f150
09-13-2015 06:39 PM
Quick Reply: 50 or 75 shot?
