2015 5.3 too much timing for 75hp shot? need help!
Im running a canned 87 diablo tune at the moment, and I will be running a 75hp- 100hp shot on the NX wet kit. Will the canned 87 tune have to much advanced timing? I talked to a guy and he said in most applications little or no timing is added in the 87 tune. What do you guys think?
I'm new to the forum by the way! And any help is appreciated! There is a lot of great info on this site and a lot of smart individuals!
hmmm... i would think that truck would probably be retarding like crazy even attempting to run 87 octane... I know both my 6.2 and NNBS 5.3 i've had pinged and pulled timing everywhere on 87 and is less compression than a new DI motor i believe. I strongly suggest trying 93 octane and contacting DS and seeing how much advance is added in the 87 and 93 tunes. That being said.. on the factory tune a 75 shot would probably be fine.. ive ran 100 shots on stock timing tables but on older NBS and NNBS trucks.
Ok I got some info, the 87 tune doesn't add any timing in WOT so I should be fine. I've ran 87 and 93 in my truck and don't notice a difference between the 2 although I'm sure 93 is much better for it. I haven't had any pinging with 87. I will run 93 though when running I'm on the gas. The new NX kit seems to be a pretty good one
IMO if that's all your running, skip the wet shot and run a dry shot before the MAF. The computer will take care of your timing and fueling up to about a 100 shot. There's a spot on those air boxs where this silly little valve or filter life thing a ma bob sometimes is, that makes the perfect place for a dry nozzle. Way cheaper than a wet set up too. That's what I did, then ended up with a wet plate and a 2 stage controller. Ran a small dry shot @ 2500 then a big one around 3500 for a total of 200-225. I had the same tuner/controller as well, I believe in the end running the Diablo tune I was pulling 8-9 degrees max for a total of 200-225ahot. Not saying that will work for you but it shouldn't differ much than my old 4.8 set up. Also assuming your truck is pretty new to you? if so I'm assuming you still have the G80 in the rear end? Once I started spraying a 75 and bigger I'd just do a 1 wheel peel. Of coarse I was trying to spray as soon as 2500 RPMS as the 4.8 had no bottom end.. but yea if you plan on having some fun with that nitrous I wouldn't spend anymore time or money on it until you get a good LSD/posi carrier in that rear end. Extreme let down after your all set up with the nitrous and you can't even hook up!
You remind me of Fast355.
Right? Was someone actually implying it was? I hope not. I was assuming he thought I was spraying my wet shot before MAF. Yikes I'm confused! Either Way like I mentioned I'd it's not to late and If the OP wants to keep it simple I suggest a dry shot befor MAF all day log. Super easy!
