150 shot questions
Old Feb 25, 2015 | 09:04 PM
MaDChevy95's Avatar
Default 150 shot questions
Alright guys got some questions. I called comp cams and they recommmended a 222/224 .566/.568 on a 112lsa cam for my 5.3. My first question is what fuel system upgrades will I need for the setup with a 150 shot? I have the smaller injectors because I'm a 99 and what pump do you guys recommend I'm soon going to be installing a fuel cell so an out of tank pump is in mind. Now I'm just getting my feet wet in this so I need your thoughts on this?
Old Feb 26, 2015 | 01:58 PM
GMC93's Avatar
walbro255 in tank pump should be plenty for now.
Old Feb 26, 2015 | 03:33 PM
MaDChevy95's Avatar
With a wet kit do I need injectors sence it takes fuel directly out of the crossover tube ?
Old Feb 26, 2015 | 04:12 PM
dirt track racer 81's Avatar
You don't need bigger injectors for a wet kit. You'll have the same injector duty cycle from a motor pass to a nitrous pass. Although you do need bigger injectors since you have a 99'
Old Feb 26, 2015 | 05:23 PM
TXsilverado's Avatar
I got away with a 150 shot on a 5.7 ls1 with the stock fuel pump just fine.
Old Feb 26, 2015 | 07:44 PM
MaDChevy95's Avatar
What size do you guys recommend? Could I use some 8.1 injectors?
Old Feb 26, 2015 | 07:48 PM
8.1 will work fine.
Old Feb 26, 2015 | 08:27 PM
MaDChevy95's Avatar
Alright guys I really appreciate the help and advice
Old Feb 26, 2015 | 11:33 PM
gamble686's Avatar
Any injector larger than stock should be just fine. Almost any fuel pump will be fine as well. I am a big fan for the aem320, but the walbro 255 should be just fine.
Old Feb 27, 2015 | 08:32 AM
gmc123's Avatar
I am currently running a 150 shot with a tsp224r cam, 8.1 inj and stock pump. No issues after about 5 bottles.
