Is a 100hp shot safe on a daily driver??
Old Dec 23, 2008 | 01:40 PM
GMCtrk's Avatar
HSW wet plate kit and their all out accessory kit. That's exactly what I'm looking at to run a 125 wet shot in the safest manner.
Old Dec 23, 2008 | 10:59 PM
LMSeven's Avatar
Search...
Old Dec 25, 2008 | 04:06 PM
built408's Avatar
any name brand kit will get the job done. I would worry more about the safety items. If you want to be safe, run tr6's, get it tuned on the bottle, and get a wideband. If you want to go the extra mile, get a standalone fuel system for it.
Old Dec 25, 2008 | 05:24 PM
skyhighsami's Avatar
no title here
I really like the idea of a stand alone fuel system that way you can run race gas with the n2o and make lots of power. What all do you need for a stand alone? Obviously a res or fuel tank, and pump. Is that it? What pump would be best?
Old Dec 26, 2008 | 12:07 AM
isenegger's Avatar
i would do a wet shot just to be a little safer. 100 shot wet with plugs would be just right.
Old Dec 27, 2008 | 08:22 PM
andrew383's Avatar
traveling mod
what happened to the guy that run like 50 bottles through his stock 4.8?? iirc he was all stock rite?ill try and find it
edit -- he ended up with 44 bottles https://www.performancetrucks.net/fo...d.php?t=405866
just run a setup like his but with smaller jets and it'll be fine
Old Dec 30, 2008 | 09:45 AM
AdioSS's Avatar
12 Second Club
a 100 shot wet or dry is safe on just about any stock V8. That is only 12.5hp per cylinder.
Old Dec 30, 2008 | 09:11 PM
Turbocoop's Avatar
I have a 100 shot wet on my DD. But I have it tuned for it, and I have a fuel pressure shut off switch and its controlled by a trick performance window switch. I also rarely use it
Old Dec 31, 2008 | 02:37 PM
EVIL Z's Avatar
i have a 75 shot on my s 10 i drive it every day. runs like a champ im about to go up to a 100 shot also... a wet shot is the way to go
Old Jan 1, 2009 | 12:34 PM
Irby's Avatar
i have a 150 on 4.8 and its my dd
