1/4 time est w/ spray?
Old 01-23-2008, 07:58 AM
strasser_3's Avatar
Default 1/4 time est w/ spray?
well the weather sucks here and no track is open yet so i just wanted to get an idea what the truck will run its a 08 silverado 1lt ecsb z71 (5.3 315 hp) got a nx 125 wet shot and a k+n intake stock tune 4 wheel drive launch spray on a 2k rpm switch (whole 1/4)
Old 01-23-2008, 08:10 AM
2nd fastest 5.3 ECSB
trever1t's Avatar
You in CA? lol, weather sucks here too.
mid 14's if you can get traction and keep the transmission from failing.
Old 01-23-2008, 08:21 AM
strasser_3's Avatar
nope missouri. traction should be no problem in 4 wheel
Old 01-23-2008, 08:24 AM
trever1t's Avatar
Launch in 4WH...shift it to 2wd right before or after the 1-2, you'll have to try trial and error. A tune will make the most of what you have.
Transmission is a very weak link, a shift kit and servos will help prolong life.
Old 01-23-2008, 08:33 AM
strasser_3's Avatar
i was gona run it in auto 4 wheel lol and if it blows up thats why they got 100k mile warranty just pull everything off and tow it to the dealer
Old 01-23-2008, 08:50 AM
TOTM: November '07
explorer5.0's Avatar
don't launch in Auto 4; launch in 4Hi and shift it to Auto or 2wd
Old 01-23-2008, 09:39 AM
trever1t's Avatar
Ok, well you probably wont have that truck long.... Warranty or not I take care of my toys.
Old 01-23-2008, 02:55 PM
99Silverado5.3's Avatar
Mid 14 sounds about right. Make sure you have some ngk tr6 spark plugs as well. Tranny should be ok due to stock torque management.
Old 01-23-2008, 03:13 PM
jdawg04 4.8's Avatar
isnt the stock tune limited to 98mph will that be a factor??
Old 01-23-2008, 04:45 PM
TOTM: November '07
No, the limiting factor will be how long the stock tune takes to go WOT with all of the torque management. No WOT= no Spray
Quick Reply: 1/4 time est w/ spray?
