P0446 Engine Code
Old Mar 1, 2016 | 03:51 PM
fireenginered1500's Avatar
Default P0446 Engine Code
I drive a 03 Silverado 1500 5.3l and it keeps throwing the code P0446. I have my own code reader and whenever I clear the code it will reappear in a day or two. Our local Chevy dealership replaced the canister and rerouted the intake line to the engine bay so it wouldn't get plugged with dirt. Code freeze frame is always lower RPM range 1500-2000 and under 55 mph.
Do any of you have information why this code is still reappearing after the dealership fixed it or is this an electrical issue? Anything will help Thanks
Old Mar 1, 2016 | 04:47 PM
Wolftrk99's Avatar
Sounds like the dealer threw a part on it... I dont have the code descritpion and diag info infront of me but... Iirc that usually points to a purge valve issue
Old Mar 1, 2016 | 05:08 PM
Is this going to ruin my fuel milage? I only get 14 now and used to get 16 but ive also put a full front ranchhand. Ill probably replace the purge valve but I didn't know if there were some voltage test I could take to find if it was electrical or not?
Old Mar 1, 2016 | 05:34 PM
Wolftrk99's Avatar
Gimme a few i can look up diag info
Old Mar 1, 2016 | 06:08 PM
From what I found, they say to check voltage at vent valve and if it good then power probe and make sure the solenoid clicks and is operational. Ill have to pull the truck into the shop tomorrow and get it cleaned up but I'm going to replace the fuel cap also just to eliminate one problem and not have the big WHAT IF
Old Mar 1, 2016 | 06:25 PM
Wolftrk99's Avatar
Heres the flow chart for it.....
If the dealer replaced the canister the vent valve and the vent line, begins to lean towrds purge valve or fuel tank pressure sensor
Old Mar 1, 2016 | 06:28 PM
Wolftrk99's Avatar
Better shot of first page
Old Mar 2, 2016 | 09:46 AM
I think I understand how the whole system works now based of youtube videos and how to test each component. Ill see what I can get figured out the next week or so. Thanks for the help!!
Old Mar 2, 2016 | 09:57 AM
Wolftrk99's Avatar
No problem.... Post back withwhat you find
vettelovralexand
Jan 26, 2018 02:00 AM
!Hostile!
Feb 25, 2016 12:21 PM
Blwn99x
Feb 20, 2016 08:43 AM
sbmalibu
Feb 7, 2016 11:04 AM
Rrodriguez13
Feb 4, 2016 02:00 PM
