Newbie needs a Lift?
I have seen and worked on two nnbs running same size tires with leveling kit, if youre gonna do it, do it right and actually put a 4 or 6 inch lift on it, leveling kits on 4wd play hell on the cv axle angles, and the tires rubbed before even close to fully turned..... Most lift manufactures rec tire/wheel sizes on their lifts just find one that recommends something close to what you have which are roughly 35x12.5 18....
Yeah............a 35ish inch tire will need a 6" lift to clear with anykind of offset. It "may" fit with less lift but your going to be chewing the hell out of the bumper/fenders.
Maybe i'm just super redneck
But if you have the tires already mounted on the wheels I would go home put them on and see whats actually rubbing. Ifs its just some plastic inner fender junk or only the very edge of the bumper I would trim it myself.
But I like the stuffed big tire look.
Not so much the big lift with tires not even the wheel well look.
But if you really want a lift I would look into BDS there stuff is a little pricy but excellent quality! and it come swith add a leafs instead of blocks and all new shocks and yada yada.
But if you have the tires already mounted on the wheels I would go home put them on and see whats actually rubbing. Ifs its just some plastic inner fender junk or only the very edge of the bumper I would trim it myself. But I like the stuffed big tire look.
