Newbie needs a Lift?
Old Nov 30, 2015 | 09:22 PM
GM1697's Avatar
Didn't see it was an 08... I'm an idiot.
Old Nov 30, 2015 | 09:55 PM
Wolftrk99's Avatar
I have seen and worked on two nnbs running same size tires with leveling kit, if youre gonna do it, do it right and actually put a 4 or 6 inch lift on it, leveling kits on 4wd play hell on the cv axle angles, and the tires rubbed before even close to fully turned..... Most lift manufactures rec tire/wheel sizes on their lifts just find one that recommends something close to what you have which are roughly 35x12.5 18....
Old Nov 30, 2015 | 10:53 PM
RS/SS 4.8's Avatar
10 Second Truck Club
Yeah............a 35ish inch tire will need a 6" lift to clear with anykind of offset. It "may" fit with less lift but your going to be chewing the hell out of the bumper/fenders.
Old Dec 1, 2015 | 12:04 AM
ckown's Avatar
Registered User
yeah i got me about 4 clicks on each side--definately thought i was doing something SMFH
Old Dec 1, 2015 | 12:11 AM
ckown's Avatar
Registered User
Thanks for all the advice - good site to learn. can yall recommend a 4" that would work at the best price? The tires were close to free so coulndt pass up
Old Dec 1, 2015 | 06:29 PM
dantheman1540's Avatar
Maybe i'm just super redneck But if you have the tires already mounted on the wheels I would go home put them on and see whats actually rubbing. Ifs its just some plastic inner fender junk or only the very edge of the bumper I would trim it myself.
But I like the stuffed big tire look.
Not so much the big lift with tires not even the wheel well look.
But if you really want a lift I would look into BDS there stuff is a little pricy but excellent quality! and it come swith add a leafs instead of blocks and all new shocks and yada yada.
Old Feb 22, 2016 | 10:29 AM
papasmurph96's Avatar
BDS sells a 4 inch high clearance lift which is really all you need if you're looking to be level, and not stack leveling kits.
SlvrSierra4.8
Dec 23, 2015 09:12 PM
blownss27
Nov 25, 2015 01:17 PM
Tyson1972
Nov 24, 2015 01:37 PM
LT1STRTOKER
Nov 14, 2015 11:41 PM
