New from Missouri/Carbed 6.0
Old Dec 24, 2010 | 05:50 PM
Steve Sr.'s Avatar
Default New from Missouri/Carbed 6.0
HI Merry Christmas to everyone. I hope the fat man in the red suit is good to all. I have a 06 GMC RCSB originally with a 4.3- 4.10's in the back, shorty headers, 2.02/1.60 manly valves, 28x9x15 slicks, and a 100 shot of nitrous. Ran a best of 14.50 @ 93 MPH. Of course that wasn't fast enough. So I found a 6.0 out of a 04 1 ton. supposedly only had 25K on it. So I put a comp cam in 224/230 dur. and 581/588 lift. Long headers. Then I got crazy....... Decided to delete the F.I. and the computer. Thats right I put a carb on it. Well then the problems started. Trans, fuel system, guages and starter wouldn't work. Well after new trans,converter and all new Autometer guages and replumbing the fuel system and a MSD ignition. With a Quick Fuel 850 cfm carb, was ready to go. See you tube Hot Rod Truck 2 and hot rod gmc #3. Then it spun a cam brging and a rod brging. Took it out and took it to a local race engine builder and spent another 4 K on it. Bored .030 with 30 over Diamond forged pistons forged scat rods. put a new cam in (same one) Had all the block work done and turned the stock crank. Still couldn't lean out carb so after 15 to 20 miles I parked it and ordered a new PRO SYSTEMS carb. when it came it was right on. Got the timing set and reset the rev limiter to 7000. It was really strong. I mean really STRONG. Went home loaded the tools jack,slicks etc. got 4 miles from home and it started making noise and the oil pressure started dropping. The race shop looked at it and said it wasn't anything they did. Was because of the quick fuel running so rich. Picked it up and crated it sent it to LME in Houston Tx. They specalize in LS motors. Now it is a 410 stroker with 11 to 1 comp. Haven't got it back yet but it is due in the next couple of weeks.
Old Dec 25, 2010 | 02:18 PM
silverado2000's Avatar
wow bad luck.
Old Dec 26, 2010 | 07:44 PM
double047's Avatar
14 Second Truck Club
Welcome.
Old Dec 27, 2010 | 02:33 PM
Steve Sr.'s Avatar
Thanks Like this site alot.
Old Jan 12, 2011 | 02:45 PM
qtshopgrl's Avatar
Registered User
You need some coffee?
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
