LS/T56 OBS from Canada
Old Aug 13, 2015 | 12:48 AM
Rick1991's Avatar
Default LS/T56 OBS from Canada
Hello, recently swapped my truck and came to check out others builds for turbo info!
Old Aug 13, 2015 | 02:25 AM
Jeebalow's Avatar
Good looking truck! I am in process of swapping an LS and t56 into my 95. Do you have any pictures of the shifter and how you did that? Are you using the shifter at the rear of the t56 or the inspection port?
Old Aug 13, 2015 | 11:09 PM
Rick1991's Avatar
Thanks! I have pics of the shifter I would just have to upload them later to post here. I did use the inspection plate, so it has the front shift conversion. I just put the motor in with the trans had the shifter on it, then I drilled a few pilot holes and sawzulled through for a hole.
Here is my build thread....
Rick's 1991 Silverado - Page 13
Old Aug 14, 2015 | 11:33 AM
Jeebalow's Avatar
Nice job on the whole thing! I'm jealous of your ctsv t56. I have an f body one and am thinking about swapping it out for a ctsv or vette t56 before adding the blower.
I also have a monster level 2 clutch. What is it like? Any chatter? That's another thing I am thinking about swapping for a dual disc lt1-s or lt1-sc from monster before installing the blower.
Old Aug 15, 2015 | 05:39 PM
Rick1991's Avatar
Thanks! Whats the difference of the transmissions? I'm probably just gonna get mine build if need be. Stage 2 is perfect, no chatter, not too stiff. I'm gonna need to swap mine soon too if I go turbo'd, wish I would've gone with a more hp one off the bat.
Old Aug 17, 2015 | 04:08 PM
Jeebalow's Avatar
Here you go, probably more than you wanted to know about t56s:
http://www.eecis.udel.edu/~davis/z28..._Fbody_T56.pdf
Glad to hear the stage 2 is a good clutch!
Old Aug 26, 2015 | 02:09 PM
Rick1991's Avatar
Interesting, I know my trans is slightly built but I'm not sure for how much power.
Tremec CTSV T56
steel shift forks
billet synchro keys
carbon fiber lined blockers
1-1/8 x 26 spline large input (LS length; GM pilot dia)
31 spline large output
Keisler internal front shift mechanism at 13.5” from front of transmission
ratios: 2.66, 1.78, 1.30, 1.0, .80, .62
fixed flange output (CTSV type)
Here is a link that helped me greatly.. 4L60e to T56 Swap - GM Truck Central
Old Aug 26, 2015 | 07:30 PM
Jeebalow's Avatar
Looks like your trans will hold up to a good amount of power. What year ctsv is it from?
That's the thread that got me interested in doing a t56 swap several years back. I still need to get the mustang shifter, but am holding off until I can see how the one that came with the relocation kit shifts.
Old Aug 27, 2015 | 10:53 PM
Rick1991's Avatar
That's good to hear and I'm not sure I bought it as a 3rd owner but it was still brand new and came with receipt and I bought it off a friends dad. All it says is CTSV. Kiesler built it. Apparently American powertrain can make you one up with a front shift conversion.
Old Aug 27, 2015 | 11:49 PM
Jeebalow's Avatar
I already rebuilt the t56. I used a keisler front shift conversion kit during the rebuild, but a mustang shifter works with the t56 in the front location by slotting the two rear holes. I will try the keisler one, then if i don't like it I will buy the mustang shifter.
Make sure to start a thread when you start your turbo build. I think one of the site sponsors sells a hot side kit for our trucks. I think it was Trick. Maybe through threads they started.
Also there is this kit that someone has been selling for 4 years
https://www.performancetrucks.net/fo...-parts-484960/
edit- what is the offset on your wheels and what size rear tires are you running? If you don't mind me asking, what was the price of the wheels?
