First truck!
Old Oct 13, 2015 | 11:36 PM
Mikeralston's Avatar
Registered User
Default First truck!
Hey guys just got my first truck! Going to be my winter ride while my motorcycle is sleeping in the garage! Also plan on towing a pop up camper and some dirtbikes this next summer!
1994 Sierra 1500 w/ 143k miles paid 900
-steering pump has a slow leak and acouple other things such as small rattle on acceleration also has 2in body lift
You guys think it's decent fixer upper for 900??
Old Oct 16, 2015 | 01:37 PM
shakesvho's Avatar
Welcome to the site!
Old Oct 16, 2015 | 01:55 PM
Klein7's Avatar
for $900, something else has to be wrong with it... but tis a good pickup
Old Oct 16, 2015 | 06:57 PM
dantheman1540's Avatar
I would throw some 35s under it cut then fenders and beat her on trails until it dies!
Thats what ends up happening to all my under $1200 trucks. but looks clean for the price should probably not do that.
Welcome.
Old Oct 16, 2015 | 07:21 PM
Vortec350ss's Avatar
For 900 absolutely... welcome aboard.
Old Oct 16, 2015 | 08:10 PM
someotherguy's Avatar
Not bad for the money!
Usual suspects with the pinging:
Check your base timing with the engine warmed up, and tan/black wire disconnected (on a '94 you'll usually find this taped into the harness bundle near the passenger side kick panel) - you want 0°; some will say go 2 to 4 but that'll give you just enough ping that you may not notice, but the PCM will and will pull back timing on you. Snug it down, re-check, plug the wire back in.
If it still pings, your EGR valve may be bad. Stuck open or opening too easily due to broken spring inside. If you have a handheld vacuum pump you can test it to see if it will hold vacuum (engine off), if it doesn't, replace. If it passes that test it could still be opening too easily, you can make a blockoff plate to test this but don't leave it like that. If you end up replacing the valve go ACDelco or Delphi only, absolutely avoid any other brand with the one-size-fits-many valves - they rarely work right on TBI engines.
Richard
Old Nov 20, 2015 | 01:54 PM
MrHorsepowerLSx's Avatar
11 Second Club
Awesome find for $900. Now get to work on that SAS and 35's welcome aboard
LSXstef
Jul 19, 2016 02:59 PM
Jordan927
Nov 10, 2015 02:47 AM
Cammed4ever
Sep 30, 2015 03:38 PM
jamesm32
Sep 24, 2015 11:49 AM
kmcn47
Sep 17, 2015 01:12 AM
