Did I do the right thing? Or am I FUBAR?
#21
I also use AEM wide bands they have worked flawlessly. Just have to have a bung welded into the exhaust for the sensor and then some very basic wiring for the gauge to have power.
Look on Atomics website for current options and prices. https://atomicfabandperformance.com/
I've seen a lot of people recommend calling Circle D for converter recommendations.
#22
Okay cool! I will track down Circle D for the converter.
I don't really do donuts or smash around corners (it's a lifted truck, so that would be dumb anyways, lol)
I definitely plan to do the exhaust as my next "project" because I was thinking of doing mid length headers and running X pipe back; but that will probably have to wait a little bit.
GREAT NEWS! I sent the Diablo chip back, lol
thank you dantheman for Atomic's website, I will order his tune soon as I get the money back from the Diablo chip.
I've said this probably a dozen times, thanks again for all the help and advice!
I definitely realize I should not have been shy/arrogant/prideful in the first place when I bought all my parts haha Its been a dream of mine for a long time to build up an LS motor and have a FUNctional daily driver truck and I think my eagerness got a bit ahead of myself.
No regrets though as I'm confident now that I didn't make a HORRIBLE mistake, just should've consulted experienced minds first haha.
dantheman1540 (05-19-2020)
#25
100% Redneck
The stock Trailblazer I6 converter will be around 2300 to 2500 stall. (Dacco reman part number B85VJCX)
Circle D takes this same converter and does their magic making it much stronger with stalls up to 3200.
I have this converter in my 2000 Sierra and It's been great.
Circle D 278mm 2600 to 3200 Stall
#26
I'll buy the Dacco reman because its HALF the price of the Circle D converter, plus Atomic's tune is $200 more than Lew's.
you think with the cam the stall and Atomics tune I'll be good to go until I can get around to exhaust?
#27
100% Redneck
When you go to with the long tubes the tune might need just a small adjustment because of the added air flow. This will probably take one or two simple data logs you'll send to Atomic. I did a camshaft swap 228/230 .585 .585 112* to a 222/232 .595 .587 108* that provided more overlap and dynamic compression.
Fired right up idled perfect and looked good on the wideband with the old tune. I did a couple data logs to re-scale the MAF and applying the new data to the tune, the MAF curve barely changed if any. Bottom line It made little to no difference between tunes/cams, but having the device, these little tweaks are simple and gives you piece of mind.
After getting the first tune... it won't be long you'll be flying solo making adjustments you may need when swapping out parts that change the airflow. If the adjustment doesn't get the results you're looking for, it's simple to load the last known good tune and try again.
In the HP Tuners editor it has a "compare" feature. You can compare two different tunes to see their differences. This really helps to see what's going on and making the tables easier to understand.
#29
Just commenting on the price difference; because I obviously have zero idea what either are capable of or the level of expertise they possess
I apologize if it seemed that way haha
