MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
What does detonation sound like
Old May 10, 2007 | 09:12 PM
OrlandoFL4.8's Avatar
yes you will know, I got it when I had the irridium plugs on the 4.8 with the 100 shot and it would detonate like there were marbles bouncing around inside my engine, kinda like pinging but louder. I ran 93 and switched to ngk tr6 plugs and it ran fine.
Old May 11, 2007 | 11:33 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Sounds expensive.
Old May 11, 2007 | 11:39 PM
2004SSS's Avatar
popcorn in your cylinders.
Old May 12, 2007 | 12:31 AM
How bad is it for your motor? AZ gas is horrible and when its hot I get it at WOT. Definately can't miss it. Need to get retuned so I can stop babying it
Old May 12, 2007 | 07:31 AM
2004SSS's Avatar
with fi very bad , n/a not as bad but it kills performance. knock retard will occur, what that is , is th emotor sensing the knock therfor retarding the timing, So you lose power. with hptuners you can set it up so the kr will take away less timing than it normally does and set it up to take away less. but as far as kr goes , its bad mmkkkkk.
Old May 12, 2007 | 10:39 AM
TchargedLS1TA's Avatar
Sounds like someone is beating your block with a hammer.. Really distinct metal-to-metal sound
Old May 12, 2007 | 01:49 PM
KySilverado's Avatar
A lot like a diesel engine idling.
lukn4trbl355
Oct 21, 2015 11:19 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
Infernohoe
48
Oct 2, 2015 10:25 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Rockrz
Sep 29, 2015 09:07 AM
