MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
a little compilation 05 crew cab
Old Mar 22, 2011 | 03:01 PM
fastjweb's Avatar
Default a little compilation 05 crew cab
the runs in this vid are all high 12's low 13's. Youll here a 12.04 in there, its actually a 13.04 on that run, dont want to bs anybody.
http://www.youtube.com/watch?v=-q1nT7qcJzM
Old Mar 22, 2011 | 03:25 PM
swift700's Avatar
Awesome, nice truck and great vid! The best part was smoking that diesel.
Old Mar 22, 2011 | 03:37 PM
fastjweb's Avatar
thankyou, yeah i usually get smoked coming out of the hole because of wheel spin, but i trap decent, The silver 350z was bolt on on a 75 shot, and then there was a black 6.0 gto and another white z that was full bolt on. I dont know what the 5.0 had done, i think he was in the 14's.
Old Mar 22, 2011 | 09:06 PM
Jake99's Avatar
Vary nice truck. You get it to hook it would damm quick for a crew cab
Old Mar 23, 2011 | 08:25 AM
rrrengine's Avatar
Damn one hell of a truck!!! Runnin strong
Old Mar 23, 2011 | 02:48 PM
fastjweb's Avatar
thanks for the comments guys, my goal is a 1.75 60ft, and when i get the 60lbs up my shifts to 6300-6500 from 5000, i hope to be knocking on 11's. We will see though. I have a roll pan instead of bumper, but other then that no wieght reduction, i think next time with the better tires and so on, ill get rid of the subs and rear seat and put my stock 17s up front instead of the 20's and get it as close as possible haha
Old Mar 23, 2011 | 11:07 PM
Faster150's Avatar
sounds pretty good!
Old Mar 24, 2011 | 08:03 PM
907TBSS's Avatar
Sounds great. She moves out for a CC.
Any future plans of cranking up the boost
Old Mar 24, 2011 | 08:10 PM
fastjweb's Avatar
907TBSS, I see the Semper Fi, Im prior enlisted Marine Corp myself, my pulley is for 9 lbs, only have had it up to 5, because im at 122% duty cycle at only 5,000 rpm, once i get the 60lbs ill run her up a little more and see what i actually get. Im thinking of running the meth injection too, not sure how much that will do for me? my goal is a 11 second crew cab. used to be 12's. did that but i fugure if i can hook with my mph i should be in the 12.1 to 12.2 range which close enough to shoot for 11's. hahah
Old Mar 25, 2011 | 09:04 PM
907TBSS's Avatar
Enlisted only way to go! I'm due for another pump to the shithole this fall.
Healthy goal and deff. obtainable I think. You know as well as I do with each degree of timing is worth plenty of HP. With that said the meth will for sure have great benefits.
With the new injectors and meth.... I assume your already on slicks... That should knock off some time. If it doesn't get you down there in the low 12's the upside is your only a 75 shot away!
I'm sure you DD the truck so a huge stall wouldn't be beneficial of both worlds..
Keep us up to date when those new injectors go in!
