MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
Imroving the looks of the tow rig!
Old Feb 6, 2011 | 08:51 PM
custm2500's Avatar
Ph.D. in HUBRIS
Default Imroving the looks of the tow rig!
New to me wheels:
Nearly final product:
The stock nuts are about flush with the wheel, so I plan to weld the NBS nut onto two nuts for each wheel. I might go 4 but haven't decided. Glue the rest the lug caps to the center cap and obviously have 2 or 4 of the lug caps holding in on like they are meant to do.
I only tacked these two to make sure the fit was OK. I need to trim about 1/8th of an inch off the nose of the NBS nut because they are out just a touch too far and will weld them up tomorrow.
I am VERY happy with the way it looks and certainly light years ahead of the stock hub caps!
Old Feb 7, 2011 | 07:53 PM
Jake99's Avatar
Yeah those caps were not cutting it, looks much better..
Old Feb 7, 2011 | 09:14 PM
custm2500's Avatar
Ph.D. in HUBRIS
What is funny is that the new caps are almost as long. But look a million times better!! I did a new set of slightly shorter lug nuts and they worked perfectly!! I glued all but two lug covers on all 4 of them. Tomorrow at work I will build the other 6 lug nuts I need and they will be permanently installed. I am so happy that with no issues they worked.
calsdad
Jun 14, 2023 11:07 PM
AdaMax
May 16, 2016 11:35 PM
cheyenne383
Nov 13, 2015 09:24 AM
SWINGRRRR
Sep 3, 2015 07:49 PM
