MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
Dem Denali's are quick!
Old 01-03-2013, 04:20 PM
Vortec350ss's Avatar
The 6.2 is nothing to sneeze at. Wait till people start to mod the ecotec 6.2 with higher compression and direct injection. It's gonna be silly.
Old 01-03-2013, 04:55 PM
Area47's Avatar
right before they figure out they can't get around the encryption code in the ecm and realize that they are limited on what they can do. it's not going to get that silly.
Old 01-03-2013, 05:48 PM
You think it will be that bad? I hope not.
Either way I'm sure people will figure out how to take advantage of direct injection on the current trucks at a minimum.
Old 01-03-2013, 05:53 PM
Area47's Avatar
playing with the di cobalts for a number of years, it's pretty easy to find the limit of the injection window fairly quickly.
Old 01-03-2013, 06:17 PM
I have a gauge for that
Atomic's Avatar
Furthermore, the ECM is not going to be easy to crack (LML duramax for instance), and I believe GM is not happy about other companies hacking their computers anyway. Which is the reason efilive no longer supports the new dmaxes.
Old 01-03-2013, 07:54 PM
HAMMER!'s Avatar
They don't make 1 7/8 headers for 4x4's so I had to improvise! I cut off the front diff mount to clear drivers side and clearanced passenger side diff mount. After seeing how much realestate I had on drivers side I built my own diff mount and every thing fits fine now!! Y pipe even fit with six speed with Vbands I added
Old 01-03-2013, 07:57 PM
Mod with training wheels
smokeshow's Avatar
Those giant ***** are slowing you down, hammer. lolol
Old 01-03-2013, 10:21 PM
HAMMER!'s Avatar
Hahaa the 60lbs ***** or 100lbs winch + bracket or 130lbs x 4 wheels or 5th wheel hitch brackets. But that's how I roll on the norm so it is what it is!
Old 01-06-2013, 04:58 PM
Formerly darynC-10/23/10
Daryn's Avatar
How did the calspeed 1-7/8 headers fit?
the headers look great. calspeed didnt surfface the flanges wortha poo. the headers hit the frame when you tighten them down . i would suggest you resurface them or use a BFH .... i used the BFH . and welded a new passenger bung in so the oxygen sensor wouldnt hit the frame
Old 01-07-2013, 03:08 PM
thunderwagen's Avatar
Man those Denalis look faster than a 392 Hemi!
03sierraslt
14
10-09-2015 05:53 AM
GMCtrk
18
10-06-2015 03:48 PM
2002_Z28_Six_Speed
10-04-2015 01:34 PM
02AWDAWSDenali
10-01-2015 05:08 PM
Quick Reply: Dem Denali's are quick!
