Cammed LS6 speedo clips
When I ordered the melling high pressure pump it cam with a thinner black o ring and a thicker green one. According to the picture that melling sent me with the way my pick up tube is it called for the green thicker one.
Plus the oilpan has been off and it has been checked to make sure the ring wasn't kinked so it even has a brand new o ring in there. It looked like it was the right thickness when it was taken off.
If the cam plate was loose it could cause the oil pressure to do this also?
And thanks for the comments guys!
Yes, oil goes through the lifter galley to the cam plate, goes behind the tchain then goes back down the other side. If the little oring ln the backside of the cam retainer plate isn't sealing to the block you will be low on pressure.
Thanks man.
ARC
57
Feb 21, 2022 10:54 AM
Offroadunleashed
Jul 20, 2015 02:25 PM
banker099
Jul 4, 2015 05:50 PM
