MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
BW S366 4.8 55-111 pull. 16-18 psi
Old Jul 24, 2016 | 12:32 PM
fastjweb's Avatar
Default BW S366 4.8 55-111 pull. 16-18 psi
Swapped the 78/75 for a S366. 16 psi through 2nd, seeing about 18 psi in 3rd. 14 degrees, meth, mid 10's afr.
looks like 6 seconds 55-111 on the logger.
Old Jul 24, 2016 | 02:56 PM
Isak81's Avatar
How does the S366 feel vs the bigger charger?
Old Jul 24, 2016 | 03:18 PM
Vortec350ss's Avatar
it certainly sounds strong.
Old Jul 24, 2016 | 03:42 PM
fastjweb's Avatar
It feels better down low and mid range. I had a 70mm on 15psi, and worked great, but it was before I had meth, and my timing was real low due to iats. When I had some time switched to the 7875 and added meth at same time. I added 5 degrees more timing, and the 78 still couldnt match the 70mm in the 8th mile, but did pick up by the quarter. the 66/73 I have now should be able to do what the 70mm did if not better, and feels just as strong as the 78 did up top. The track will tell lol. I think for my combo, small motor, small cam, this smaller turbo will shine. Its goals too though, I know the limits of my fuel system, and dont plan on going faster then 10.80s. so im trying to have something that will be as effecient as possible, reach my track goals, and be a fun street truck.
Old Jul 24, 2016 | 04:42 PM
10.80's! Damn those are good times.
You and I have similar goals. I have a lofty 10.7x in my mind... its going to be hard to accomplish.
Old Jul 24, 2016 | 05:20 PM
GMCtrk's Avatar
Looks fast from the speedo.
Breaking down the 10s barrier is hard
Old Jul 24, 2016 | 05:32 PM
fastjweb's Avatar
10's is hard lol. 70/64 11.02 at 121.2 15 psi 9.5 degrees
78/75 11.07 at 121.7 15 psi 14 degrees/meth
66/73 ? lol
Old Jul 24, 2016 | 05:36 PM
fastjweb's Avatar
Good luck to you on your mission!!! I dont know the perfect combo, The MP70 on low timing and rich AFR, PTC 3500 and 3.90s, 214/218 562/562 111 lsa cam got me damn close. Granted its 4400lbs, so if this S366 gets me there, I think its very streetable combo that will work for the single cab guys with 4.8s.
Old Aug 2, 2016 | 10:13 AM
Choda's Avatar
This is the same exact thing I am doing right now. I have a 5.3 w a triple 12 and 70/65 on pump at 11 psi. Makes ~500 wheel. I just got meth, Trick 5 inch race intercooler and a 78/75. I really hope the meth and turbo work together to keep my short times the same if not better and allows me to pick up power on the top end. BUT what you have provided is the opposite data. arg
Old Aug 2, 2016 | 05:09 PM
fastjweb's Avatar
Choda, i texted you. truck still has 3" intercooler and full exhaust. open wastegate dump now though.
SLOPONY
Jul 11, 2016 04:32 PM
3 window
Jul 11, 2016 01:03 PM
abshire1006
Jul 9, 2016 09:30 AM
40series
Jun 28, 2016 11:01 PM
