Beastmode's Project!
Import Moderator
Well I got the motor and trans out, cam will be come out shortly to head off to its new owner and the converter as well. Then im gonna order my new parts Monday (hopefully).
The trans will be headed back to the shop to have an overall look done on it. It is a built vacuum modded 4L60E with all the goodies.
As far as motor im going with the same cam TxSilverado & AP2002 have and hopefully a set of Patriot Performance Stage II 243s. I will also have most of my brackets for the motor I can get powdercoated
The exhaust will be getting lengthend to fit the extended cab and the LTs ceramic coated so they dont look like sheet anymore.
Import Moderator
tell me bout it, when me and Quik sealed the oil pan we must have messed something up cause its a mess. as far as the timing cover that front main seal is def leakin
Ya pulled everything yesterday... then took it from the lift and put it right in the back of the extended cab as was when we pulled it... then I got home and seperated everything (wiring harness, tranny, motor, converter blah blah blah... right in the bed of the truck LOL)
Ill post pics of the whole process if i remember
