MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
1/4 mile passes
Old Jun 14, 2007 | 07:12 AM
ChevyThunder17's Avatar
What was your tire pressure at? Over 20 psi? If so, air those puppies down.
Old Jun 14, 2007 | 07:13 AM
beastmode's Avatar
Import Moderator
Originally Posted by trever1t
Definately
I understand frustrated, I was stuck at 15.0 and couldn't break 14 with the setup I was running, na.
Keep at it. I drop time amolst every trip I make to the track
thanks for the words of encouragement, it makes it worth keepin at it
Old Jun 14, 2007 | 07:14 AM
beastmode's Avatar
Import Moderator
i think we set it to 18.5 lbs. it was about 70deg dunno if that matters
Old Jun 14, 2007 | 07:18 AM
wkdivr's Avatar
Try lowering tire pressure, like 1 pound at a time. Bump in to light the top light, pump up the brakes real good, and try to leave at arounbd 1000, or so. Also, you need to do a good hard burnout to make sure you don't have water on your tires. You goin to Quaker city this Fri? I'm thinking of going.
Old Jun 14, 2007 | 07:22 AM
beastmode's Avatar
Import Moderator
ok, ya i didnt touch tire pressure at all last night, i should have been
no i dont think so, im gonna try to stay away from racing a lil to i atleast get the trans built. i dont know if they are doing testntune this friday are they?
Old Jun 14, 2007 | 08:20 AM
Mater's Avatar
congrats,it will get better with weather & i;ll tech u some tricks!
Old Jun 14, 2007 | 09:37 AM
duwem's Avatar
Tell the ricers to turn there fart cans down so we can hear your truck!
Old Jun 14, 2007 | 02:30 PM
beastmode's Avatar
Import Moderator
hell ya
Old Jun 14, 2007 | 10:40 PM
BoostedDenali04's Avatar
hey man good runs! Defineatly go with some lower tire pressure, you got yourself some good ET streets so heat them up real good and they should stick real nice. Congrats on the low 14 second passes and get that thing into the 13's!
Old Jun 14, 2007 | 11:21 PM
He has ET Streets already, just needed to air them down s'more and fix the knock sensor issue.
Choda
Jan 22, 2026 02:03 PM
Oobray
Jun 13, 2022 03:38 AM
Bluchevypick
Aug 8, 2015 10:35 AM
BennyB
Aug 1, 2015 08:48 AM
fcompean
Jul 15, 2015 09:55 PM
