Miscellaneous Classifieds Anything not vehicle specific
1968 Camaro
Old Sep 9, 2007 | 07:18 PM
Dbl G's Avatar
Default 1968 Camaro
1968 Camaro
Originally; 327 SB 4 speed 10 Bolt rear axle
White with Red Standard Interior
This is a rolling frame/body in need of finsh.
Interior is whole however in need of replacement
Body is in need of paint and metal work
All parts are here to completely assemble
Less transmission of some nature
Most stock parts are also with vehicle.
It has been garaged for 15 years in my ownership. $ 11,000.00
N.O.S. parts;
Big block radiator
Core support
New head bolt set
Head bolt washers
S.S. washers for intake bolts
Carb to intake gasket
Throttle linkage knuckle
2 – Jet kits for re-jetting Barry Grant carb
Trunk seal kit adjustable fuel line feeds
Fel-Pro head gasket set
Drive shaft loop
Header gaskets
Dual remote oil filter base
Oil filter canister adapter
Fuel filter with pressure gauge
Console lid
Value stem seals
Hood blanket and install kit
Glove box insert
Lower and upper radiator hoses
Radiator support pads
2- Spare instrument clusters one of which is a 160MPH
Glove box install kit
All window felt kits S.S.
Door jam to window seals rear
Performance oil pump shaft
Roof rail weather stripping
Door seals
Front body assembly hardware
Cowl hood wiring harness
Cowl hood seal
Rear window seals
Inner fender well passenger side
Outer fender passenger side
Drivers side and Passengers side rear Full Quarters
Inner fender well skirt kits
Intake manifold gaskets
Engine belts
Radiator pet-**** value
A/C & Heater damper rods
Shifter console brackets
Carb filter
ARP complete engine bolt kit
Cowl to firewall seal
Spin on oil filter adapter
Temperature sending unit for BB Chevy
Body panel shim kit
Trunk lid bumpers
Front core support assembly kit
Outer and inner fender kits
Headlight and Bezel kits
Hood hinge bolt kit
Inner fender well cup kit
Battery tray
Spare instrument bezel
New trunk lid
Lower rocker panel trim
Muncie shifter & **** and all correct linkage
Trunk floor pan
BB heater core
BB heater core cover
Front and rear shocks BB
BB front end bushings
BB front coil springs
Frame too Body bushings
BB motor mounts
BB transmission mount
__________________________________________________ ________
Other goods not new or correct for year;
69 trunk lid spoiler
69 cowl hood (not new)
68-69 floor console
A-Body 12 Bolt rear axle assembly
1973 Chevy Big Block 427 truck block (Tall Deck)
1973 049 casting cylinder heads worked
Clevite bearings
All internals new
Lift is Hydraulic
Full race cam
Barry Grant 1050 CFM carburetor (New never fueled)
MSD crank trigger set-up
MSD low-profile crab style distributor
MSD 6 AL ignition set-up with rev limiter
MSD blaster 3 coil
MSD 8MM silicon plug wire set
New champion plugs
Ceramic coated 1 7/8 primary headers 3” collectors, new never fired
New exhaust system to rear axle never fired
Weiand team G dual plane mid rise intake
High volume oil pump
New short nose high volume water pump
Engine fresh rebuild not bored out still remaining 120 bore over
10/10 Steel crank
Stock connecting rods and pistons
8 Quart oil pan
Edits;
Additional items will be listed soon,,,,,,
Front brake calipers and rotors. bearings
Races/ Seals
Front brake lines
Old Sep 9, 2007 | 07:25 PM
nightrunner's Avatar
Mr. Obvious
price?
Old Sep 9, 2007 | 07:29 PM
Dbl G's Avatar
11k.....
Old Sep 11, 2007 | 04:55 AM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Pics??
Chevy305
Sep 28, 2015 09:21 PM
97_ek
Sep 23, 2015 09:16 PM
dirt track racer 81
Sep 21, 2015 06:44 PM
Roody0209
Sep 17, 2015 09:06 AM
