Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
Spraying the lil 4.3... got ???s
Old Aug 24, 2007 | 09:48 AM
ChevyThunder17's Avatar
That's correct; Central Point Injection.
Should be about 80+ psi. But I don't think you can remove the vacuum for the FPR.
Old Aug 24, 2007 | 12:41 PM
nonnieselman's Avatar
Ok i was just wondering...
So when im tryin to find out what jets to use what Fuel PSI do i need to use?
Old Aug 24, 2007 | 01:00 PM
You'll probably pull the fuel from that schrader valve, so 80 psi is what I'd base it on for the fuel nozzle.
Old Aug 24, 2007 | 06:04 PM
Yea i knew that, Ill have a LM1 hooked up to check the AFR..
I think i can do the COS and run it to pull timing when the arm switch is turned on... i think...
Old Aug 24, 2007 | 10:47 PM
Dogsofjune's Avatar
That's not quite correct. It's CSFI. Central Sequential Fuel Injection on the '96 and newer 4.3's.
Old Aug 24, 2007 | 10:53 PM
I was thinking of the 92-95's for some reason; yes, it's sequential, not port.
It's a really shitty system if you are looking to make power. You have no ability to up your injector size and the fuel pressure is already through the roof.
Old Aug 25, 2007 | 08:28 PM
Dogsofjune's Avatar
Yes, I agree with it being a bad system for performance. Yet with a wet 75 shot on the 4.3, there isn't much to worry about.
Fortunately, some of us with the 4.3 S-10's have overcome the fueling issue so we have the potential to make some power.
denalircsb
Dec 21, 2020 09:04 AM
thompson
Dec 27, 2017 06:48 AM
twake_410
Apr 14, 2016 09:58 PM
sTNT971
Sep 26, 2015 04:22 PM
sprayed99
Sep 14, 2015 12:36 PM
