Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
Which Hood: Carb'd LS S10
Old 06-02-2012, 08:14 PM
Registered User
SoLo64's Avatar
Question Which Hood: Carb'd LS S10
I do not enjoy running wires in tight spots so I plan to go with a carb on the Performer RPM manifold on a 4.8L. I will start a project thread when I start the install. So, I plan to add a cowl induction hood and seal the carb/air cleaner assy to it. Have any of you done the carb route on your LS10? I no longer have to smog it so its wide open on mods. Turbos and a FAST fuel injection setup are down the road.
So what height cowl hood have you used? I was thinking the 3.5" should be enough but if the 2.5" would work its a few more bucks left in my pocket .
Old 06-03-2012, 11:38 AM
TXsilverado's Avatar
i'm in the middle of a carb s10 swap. i'm assuming you're in a 1st gen s10 since you dont have smog anymore?
Old 06-03-2012, 04:16 PM
Registered User
SoLo64's Avatar
Its a 91 and the county its registered in doesn't smog check. I have never had to in 6 plus years.
Skip Fix
22
07-09-2016 07:08 PM
KINGCYCLES
10-02-2015 10:21 AM
Go5.3tt06
09-24-2015 08:12 PM
dirt track racer 81
09-21-2015 06:44 PM
Sdailey
09-06-2015 10:26 PM
Quick Reply: Which Hood: Carb'd LS S10
