Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
Which Hood: Carb'd LS S10
Old Jun 2, 2012 | 08:14 PM
SoLo64's Avatar
Registered User
Question Which Hood: Carb'd LS S10
I do not enjoy running wires in tight spots so I plan to go with a carb on the Performer RPM manifold on a 4.8L. I will start a project thread when I start the install. So, I plan to add a cowl induction hood and seal the carb/air cleaner assy to it. Have any of you done the carb route on your LS10? I no longer have to smog it so its wide open on mods. Turbos and a FAST fuel injection setup are down the road.
So what height cowl hood have you used? I was thinking the 3.5" should be enough but if the 2.5" would work its a few more bucks left in my pocket .
Old Jun 3, 2012 | 11:38 AM
TXsilverado's Avatar
i'm in the middle of a carb s10 swap. i'm assuming you're in a 1st gen s10 since you dont have smog anymore?
Old Jun 3, 2012 | 04:16 PM
SoLo64's Avatar
Registered User
Its a 91 and the county its registered in doesn't smog check. I have never had to in 6 plus years.
Skip Fix
22
Jul 9, 2016 07:08 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
Go5.3tt06
Sep 24, 2015 08:12 PM
dirt track racer 81
Sep 21, 2015 06:44 PM
Sdailey
Sep 6, 2015 10:26 PM
